Downsampling MP3s
Downsampling MP3s
Postby plowman » Wed Aug 22, 2012 1:11 am
So, I upgraded to 4.7b3 (from 4.5) and any mp3s exceed the max bitrate and need downsampling do not work. I get nothing in the log that I do not expect, and no unhandled exceptions that I can see. All of the options for downsampling are identical to the recommendations.
Log:
[2012-08-21 21:08:04,112] INFO PlayQueueInputStream - plowman listening to "Rascal Flatts - Changed/01 Rascal Flatts - Changed.mp3"
[2012-08-21 21:08:04,118] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/mp3/Country/Rascal Flatts - Changed/01 Rascal Flatts - Changed.mp3] [-ab] [96k] [-v] [0] [-f] [mp3] [-]
FFMpeg is current and when I run that exact command from a terminal it works fine.
Any suggestions or places to investigate?
EDIT-1: Turns out command line execution isn't working fine. The file gets downsampling but the header is messed up for some reason. This is obviously a FFMpeg problem.
[mp3 @ 0x6385e0] Header missing
    Last message repeated 190 times
If I output to a file "... -f mp3 song.mp3" I get a valid MP3. If I output to STDOUT and redirect to a file "... -f mp3 - >song.mp3" I do not get a valid file. Regardless of the song I downsample the one outputting directly to a .mp3 file is always 309 bytes larger than the one I output to STDOUT and redirect to a .mp3 file.
plowman
Re: Downsampling MP3s
Postby mellofone » Thu Sep 06, 2012 7:20 pm
I have the exact same problem. But I don't see this with ALL of my collection, only a very select few albums. I've even tried to upgrade to a git version of ffmpeg and the problem persists. Reverting my downsample command back to using lame has it working perfectly again:
lame -S -h --resample 44.1 -b %b --tt %t --ta %a --tl %l %s -
mellofone
Postby unhammer » Thu Nov 29, 2012 3:37 pm
Ah, thanks! That solved it for me too =D I did get something odd in my /var/subsonic/subsonic.log though:
[2012-11-29 16:13:15,314] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/home/test/test.mp3] [-ab] [256k] [-v] [0] [-f] [mp3] [-]
[2012-11-29 16:13:26,925] WARN RESTFilter - Error in REST API: EofException
org.mortbay.jetty.EofException
   at org.mortbay.jetty.HttpGenerator.flush(HttpGenerator.java:760)
   at org.mortbay.jetty.AbstractGenerator$Output.blockForOutput(AbstractGenerator.java:546)
   at org.mortbay.jetty.AbstractGenerator$Output.flush(AbstractGenerator.java:567)
   at org.mortbay.jetty.HttpConnection$Output.flush(HttpConnection.java:907)
   at org.mortbay.jetty.AbstractGenerator$Output.write(AbstractGenerator.java:628)
   at org.mortbay.jetty.AbstractGenerator$Output.write(AbstractGenerator.java:575)
   at net.sourceforge.subsonic.controller.StreamController.handleRequest(StreamController.java:221)
   at net.sourceforge.subsonic.controller.RESTController.stream(RESTController.java:1080)
   at sun.reflect.GeneratedMethodAccessor175.invoke(Unknown Source)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
   at java.lang.reflect.Method.invoke(Method.java:616)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
   at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
   at net.sourceforge.subsonic.security.RESTRequestParameterProcessingFilter.doFilter(RESTRequestParameterProcessingFilter.java:110)
   at net.sourceforge.subsonic.filter.RESTFilter.doFilter(RESTFilter.java:51)
Caused by: java.io.IOException: Broken pipe
   at sun.nio.ch.FileDispatcher.write0(Native Method)
   at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:47)
   at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:122)
   at sun.nio.ch.IOUtil.write(IOUtil.java:78)
   at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:352)
   at org.mortbay.io.nio.ChannelEndPoint.flush(ChannelEndPoint.java:166)
   at org.mortbay.io.nio.SelectChannelEndPoint.flush(SelectChannelEndPoint.java:208)
   at org.mortbay.jetty.HttpGenerator.flush(HttpGenerator.java:693)
   ... 67 more
putting it up in case it's helpful for other searchers :)
unhammer
