Cant log in into https
Postby peffag » Sun Aug 26, 2012 8:20 am
Hi !
I'm new to Subsonic.
First I installed an Ubuntu server 12.04 user "myAccount" with low access to my computer.
I can access to computer with that usernamn "myAccount" and password "myPassword" , so far...
I change my /etc/default/subsonic to ...
SUBSONIC_ARGS="--port=0 --https-port=443 --max-memory=600 --default-music-folder=/home/mymusic/subsonic --default-playlist-folder=/var/subsonic/playlists --default-podcast-folder=/var/subsonic/podcast"
SUBSONIC_USER=root
When I try to login with https://mycomputer.se
The page appear and I type "myAccount" name and password "myPassword" but I was rejected.
I have not assign any other password than "myPassword" on Ubuntu. Do I miss something ?
The subsonic.log tell me ...
[2012-08-25 12:16:13,819] INFO DaoHelper - Checking database schema.
[2012-08-25 12:16:14,571] INFO DaoHelper - Done checking database schema.
[2012-08-25 12:16:14,894] INFO SearchService - Automatic index creation scheduled to run every 1 day(s), starting at Sun Aug 26 03:00:00 CEST 2012
[2012-08-25 12:16:15,013] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Sat Aug 25 12:21:15 CEST 2012
[2012-08-25 12:16:18,003] WARN NetworkService - Failed to delete port mapping.
java.lang.RuntimeException: Error during lazy SCDP file parsing at http://134.25.105.1:49152/ipcfg.xml
at net.sbbi.upnp.services.UPNPService.parseSCPD(UPNPService.java:227)
at net.sbbi.upnp.services.UPNPService.lazyInitiate(UPNPService.java:295)
at net.sbbi.upnp.services.UPNPService.getUPNPServiceAction(UPNPService.java:138)
at net.sbbi.upnp.messages.UPNPMessageFactory.getMessage(UPNPMessageFactory.java:87)
at net.sbbi.upnp.impls.InternetGatewayDevice.deletePortMapping(InternetGatewayDevice.java:412)
at net.sourceforge.subsonic.domain.SBBIRouter.deletePortMapping(SBBIRouter.java:61)
at net.sourceforge.subsonic.service.NetworkService$PortForwardingTask.execute(NetworkService.java:167)
at net.sourceforge.subsonic.service.NetworkService$Task.run(NetworkService.java:309)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask$Sync.innerRunAndReset(FutureTask.java:351)
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:178)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:165)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:267)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:679)
Is it a Router problem, It says "error during lazy SCDP file parsing att my router adress "134.25.105.1"
I have opend the port 49152 on the Router, is there a uPnP problem ?
Please give my an advise -::---)
Best Regards Per Fagerkvist
peffag
Re: Cant log in into https
Postby hakko » Sun Aug 26, 2012 8:43 am
I can't tell for sure if "myAccount" that you refer to is a Subsonic user or an actual account on your computer. Have you tried logging in with user "admin" and password "admin" to Subsonic, which is the default user?
MusicCabinet developer
hakko
Postby peffag » Sun Aug 26, 2012 8:56 am
Hi !
Yes it works with admin /admin.
Where do I set the password for "myAccount"
and how do I disable the admin / admin login ?
peffag
Postby peffag » Sun Aug 26, 2012 8:59 am
Sorry ... I have to read first then ask !
peffag
