Redirection Error - username.subsonic.org address.
Postby mutestar » Sun Aug 26, 2012 6:06 pm
Recently I've noticed that my username.subsonic.org address seems to be forwarding to the wrong page.
My sub page is redirecting to http://169.254.246.176:499/cgi-sys/defaultwebpage.cgi
which displays the following error:
HTTP ERROR: 404
NOT_FOUND
RequestURI=/cgi-sys/defaultwebpage.cgi
Powered by Jetty://
If I remove the /cgi-sys/defaultwebpage.cgi part of the address the connection loads correctly.
This redirection issue has been occuring for the last 3 days.
Subsonic is loading correctly locally as well. (localhost:499)
Is there anything I can do on my end or does this sound like a server issue?
Bryan
mutestar
Re: Redirection Error - username.subsonic.org address.
Postby jaume » Tue Aug 28, 2012 5:38 pm
Hi there,
I am having the exact same issue with my subsonic.
This only happens in the host PC and it is completely fine when accessing it from other PCs.
Any ideas?
jaume
Postby toolman » Tue Aug 28, 2012 7:34 pm
on what operating system is your Subsonic-setup running?
Ubuntu, Windows?
Versions?
toolman
Postby GJ51 » Tue Aug 28, 2012 8:53 pm
it's an internal DHCP issue that indicates that your router is not giving your host PC an internal ip address. Shut down the PC, reboot the router, restart the host PC and verify that it has been given the correct internal ip address by the router. Then verify that the port forwarding to that ip is correct.
Postby mutestar » Tue Aug 28, 2012 8:56 pm
That's actually what just fixed the error for me. Restarted PC/Router, resaved port settings in sub. Also disabled UPnP settings and just did manual port forwarding to a new port and sub is now working correctly.
mutestar
