Need help using iTunes playlists in Subsonic 4.5 (& 4.6)
Postby daggem » Wed Aug 29, 2012 7:04 pm
Hi
I'm new to Subsonic. The setup was easy and Subsonic finds my music media in preset folders. But how can I export iTunes playlists to Subsonic or even better how can I get Subsonic to scan them (since I frequently change those in iTunes and I like them updated in Subsonic too)? Any ideas? I have also tried version 4.6, but with the same frustrating hurdle not understanding how to "sync" iTunes/Subsonic playlists... A million thanks in advance... Regards /daggem
daggem
Re: Need help using iTunes playlists in Subsonic 4.5 (& 4.6)
Postby BKKKPewsey » Thu Aug 30, 2012 10:49 am
You need to export your iTunes playlist into a standard format that SS will understand eg m3u.
Also the path names will need to be the same so SS can find the files.
Suggest you check out http://www.ericdaugherty.com/dev/itunesexport/
Postby daggem » Thu Aug 30, 2012 8:14 pm
Thanks a lot. Works now. Best regards //daggem
daggem
Users browsing this forum: Bing [Bot] and 22 guests
