After 2 years, USERNAME is registered but cannot connect.
Postby innerspaceboy » Mon Sep 03, 2012 11:37 pm
Problem Description:
STATUS: innerspaceboy.subsonic.org is registered but could not connect to it. (ConnectTimeoutException)
I have used Subsonic for 2 joyful years on my Windows 7 partition to access my home library on my Droid X. Yesterday, halfway into a playlist, it stopped downloading and since then nothing I do makes it download anymore.
NOTE that I could still view my entire library on my Droid X, and when I tested the connection under the SETTINGS menu, connection instantly reads "OK."
Troubleshooting Steps:
1) Freed space on my micro SD.
2) Ended Subsonic task and restarted
3) Cleared application cache
4) Stopped and restarted Subsonic tray icon on my PC
5) Uninstalled the app and reinstalled
6) Factory reset my phone
7) Still no luck, so I ventured over to my Ubuntu 11.10 partition and installed Subsonic
8 ) Successfully port forwarded 4040 but easy-to-remember address status fails and reports -
Accessed my router and modified the existing Port Forward exception from Subsonic - 80 to Subsonic - 80, 4040.
9) While using the Ubuntu version of Subsonic my Droid X can no longer see my library and times out if I try to connect to innerspaceboy.subsonic.org.
Playback Application and version: Subsonic mobile 3.3
Subsonic Version: 4.6 (build 2585)
Server Version: jetty-6.1.x, java 1.6.0_24, Linux (41.6 MB / 47.0 MB)
Hardware Platform: Ran fine until yesterday under Windows 7. If I can successfully get it running under Ubuntu 11.10 I'll finally be free to sever my ties from Microsoft! Please help me make this dream a reality!
Java Memory Limit: Not sure where to find this in Ubuntu, sorry.
Output from ffmpeg -i: The program 'ffmpeg' is currently not installed. You can install it by typing: sudo apt-get install ffmpeg
Last log file lines:
[9/3/12 6:34:58 PM EDT] INFO VersionService Resolved latest Subsonic final version to: 4.6
[9/3/12 6:34:58 PM EDT] INFO VersionService Resolved latest Subsonic beta version to: 4.7.beta3
[9/3/12 6:35:36 PM EDT] INFO PodcastService Starting scheduled Podcast refresh.
[9/3/12 6:35:36 PM EDT] INFO PodcastService Completed scheduled Podcast refresh.
[9/3/12 6:35:58 PM EDT] INFO SecurityService Created user innerspaceboy
[9/3/12 6:37:22 PM EDT] INFO PlayerDao Created player 2.
[9/3/12 6:38:43 PM EDT] INFO MusicFolderDao Created music folder classybastard/audio
[9/3/12 6:39:22 PM EDT] INFO NetworkService Deleted port mapping for port 4040
[9/3/12 6:39:46 PM EDT] INFO NetworkService Successfully forwarding port 4040.
[9/3/12 6:49:41 PM EDT] INFO MusicFolderDao Created music folder /media/classybastard/Video
[9/3/12 6:51:46 PM EDT] INFO NetworkService Successfully forwarding port 4040.
[9/3/12 7:06:30 PM EDT] INFO NetworkService Successfully forwarding port 4040.
Thank you sincerely in advance.
innerspaceboy
Re: After 2 years, USERNAME is registered but cannot connect
Postby GJ51 » Tue Sep 04, 2012 3:13 am
I'm not too sure where you're at with this, but your address is not responding, so it's not your phone; the server isn't responding. i don't use Linux so I can't help you there, but if you want to bring a Windows install back up I'll be glad to help.
I use the WAR version on my Windows servers and it runs fine.
Otherwise you'll have to wait for one of the Linux guys to give you a hand.
From reading the other thread you started, it sounds like it's definitely your server that's not responding, You need to get that up and verified before worrying about the phone.
Postby innerspaceboy » Thu Sep 06, 2012 5:10 am
All right, back to the Windows partition where it originally stopped working mid-stream.
Noticed that I could not connect to the Subsonic login page from Firefox due to NoScript. Disabled NoScript and it connected fine. Took a look at the About page and found the following lines:
[9/6/12 12:40:43 AM EDT] INFO DaoHelper Checking database schema.
[9/6/12 12:41:01 AM EDT] INFO DaoHelper Done checking database schema.
[9/6/12 12:41:11 AM EDT] INFO VersionService Resolved local Subsonic version to: 4.6
[9/6/12 12:41:24 AM EDT] INFO SearchService Automatic index creation scheduled to run every 1 day(s), starting at Thu Sep 06 03:00:00 EDT 2012
[9/6/12 12:41:27 AM EDT] INFO PodcastService Automatic Podcast update scheduled to run every 24 hour(s), starting at Thu Sep 06 00:46:27 EDT 2012
[9/6/12 12:41:33 AM EDT] INFO NetworkService Successfully forwarding port 80.
[9/6/12 12:45:21 AM EDT] ERROR SearchService An error occurred while reading index entry 'F ixYxi 1331507111087 ixYxi 1331507111087 ixYxi e:\audio\Soul Coughing & Mike Doughty - Live & Rarities Collection\Mike Doughty\Double Door Chicago IL 11.13.03\25. Janine (Mike Solo).flac ixYxi 43971064 ixYxi MIKE DOUGHTY ixYxi DOUBLE DOOR CHICAGO IL 11.13.03 ixYxi 25. JANINE'.
[9/6/12 12:45:21 AM EDT] ERROR SearchService An error occurred while reading index entry ''.
[9/6/12 12:45:21 AM EDT] ERROR SearchService An error occurred while reading index entry '* MIKE SOLO ixYxi ixYxi '.
[9/6/12 12:45:27 AM EDT] WARN JaudiotaggerParser Error when parsing tags in e:\audio\Cocteau Twins\Cocteau Twins - Singles & EPs\Cocteau Twins - EPs\Cocteau Twins - Love's Easy Tears [1986]\COCT#7OS.MP3
[9/6/12 12:46:27 AM EDT] INFO PodcastService Starting scheduled Podcast refresh.
[9/6/12 12:46:27 AM EDT] INFO PodcastService Completed scheduled Podcast refresh.
[9/6/12 12:57:22 AM EDT] INFO VersionService Resolved latest Subsonic final version to: 4.6
[9/6/12 12:57:22 AM EDT] INFO VersionService Resolved latest Subsonic beta version to: 4.7.beta3
Noticed that Windows is using Port 80 while Ubuntu was forwarding to 4040. 80 had always worked fine in the past up until this week. The truncated long file paths were always listed as well so I don't think they're the issue.
I do have multiple security softwares running, one of which may have updated and is now blocking subsonic.
I have Peerblock, Immunet 3.0 and AVG Free as running processes and manually run Malwarebytes AntiMalware once a week. Immunet is painfully difficult to disable so I tried restarting in safe mode with networking but Subsonic doesn't seem to be able to operate in that environment.
Hoping now that I'm back to the Windows side someone will be able to help me?
innerspaceboy
Postby GJ51 » Thu Sep 06, 2012 5:30 am
Never use port 80 or 443. Yes it can be done. Nore often than not it just causes unnecessary problems from a variety of sources. I have multipl servers/instances of SS for testing various hardware and configuration variables. i use a pretty simple scheme to keep it easy to remember what I'm doing. I usually place my servers into high addresses to minimize the possibility of DHCP conflict.
eg.
192.168.1.240 uses 4040 and 440
192.168.1.241 uses 4041 and 441
192.168.1.242 uses 4042 and 442
SKIP 243 to avoid using 443
192.168.1.244 uses 4044 and 444
Using a schene like this makes life a lot easier when you have to edit the port forwarding rules.
You can use any setup you like but experience with hundreds of other users has taught me that just avoiding 80/443 makes everyones life much easier.
Postby innerspaceboy » Fri Sep 07, 2012 12:22 am
After experiencing difficulties with sound today both in Ubuntu and Windows (my PC appears to be locked in surround sound mode and all vocals are muted as I only have stereo sound) I reinstalled Windows only to find that the problem persisted.
I've just reinstalled Subsonic. It retained my username, password, and that it had been registered, but I cannot specify my audio folder. I read the Getting Started Guide and clicked on Settings but my screen looks nothing like the interface I remembered. The boxes where you enter media folders are missing. The Settings screen only shows PERSONAL, PASSWORD, PLAYERS, and SHARED MEDIA.
Last lines in the log:
[9/6/12 5:34:36 PM PDT] INFO MediaScannerService Media library never scanned. Doing it now.
[9/6/12 5:34:36 PM PDT] INFO MediaScannerService Starting to scan media library.
[9/6/12 5:34:37 PM PDT] INFO PodcastService Automatic Podcast update scheduled to run every 24 hour(s), starting at Thu Sep 06 17:39:37 PDT 2012
[9/6/12 5:34:38 PM PDT] INFO MediaScannerService Scanned media library with 0 entries.
[9/6/12 5:34:38 PM PDT] INFO MediaScannerService Marking non-present files.
[9/6/12 5:34:38 PM PDT] INFO MediaScannerService Marking non-present artists.
[9/6/12 5:34:38 PM PDT] INFO MediaScannerService Marking non-present albums.
[9/6/12 5:34:38 PM PDT] INFO MediaScannerService Completed media library scan.
[9/6/12 5:34:40 PM PDT] INFO NetworkService Successfully forwarding port 80.
[9/6/12 5:34:49 PM PDT] INFO VersionService Resolved latest Subsonic final version to: 4.6
[9/6/12 5:34:49 PM PDT] INFO VersionService Resolved latest Subsonic beta version to: 4.7.beta3
Anyone know what's happening?
NOTE As I've reinstalled my OS and Subsonic and this is a new issue all together I have submitted a new help request post with more relevant information. Please see my new post instead. Thank you.
innerspaceboy
