Connection failure with Android App
Postby Nusser » Tue Sep 04, 2012 10:14 pm
I have tried everything posted on the frorum for not connecting with my server with the andoid app. No success.
I can accessmy server over the web with the iphone app!
This is simply enoying, I today received my new asus pas, so I am not really an expert in using Android, but this is a pain.
The error message is "Connection failure.Illegal character in query at index 40
Please help!
Thx
Carsten
Nusser
Re: Connection failure with Android App
Postby GJ51 » Tue Sep 04, 2012 11:55 pm
Can the phone connect properly to the Subsonic Demo server?
Postby Nusser » Wed Sep 05, 2012 9:11 am
Yes the tab can connect to the demo server
Nusser
Postby Nusser » Wed Sep 05, 2012 10:30 am
I just tried to connect from the outside and not from my network where my server is connected, same error!
Nusser
Postby bushman4 » Wed Sep 05, 2012 5:35 pm
What is the username that you are using? Does it work in the web interface?
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby GJ51 » Wed Sep 05, 2012 6:07 pm
Got to http://canyouseeme.org and see if the Subsonic port is open.
This might also be due to a Java stack overflow condition:
http://www.google.com/search?hl=en&q=Il ... 2040%0D%0A
I'd suggest stopping the Subsonic service then uninstalling all Java instances/upgrades on the server, then download and install the latest version of Java for your server. Restart Subsonic and see if you still have a problem.
Postby Nusser » Wed Sep 05, 2012 10:01 pm
Carsten Lund is the User Name
The port is open from the outside, I did check.
I will try to reinstall java and let you know whether it helps
Thx so far
Nusser
Postby Nusser » Thu Sep 06, 2012 12:20 pm
Hi everybody,
reinstalling java did not help.
I solved the Problem though, don't use a space in the Username. I tried another account with a user name without a space. It worked.
Would have been nice to see this posted somewhere.
Nusser
Thx for the help anyways!
Nusser
