Can't understand why Subsonic stopped working
Postby kobhqlt » Fri Sep 07, 2012 2:05 am
I come to you today because my subsonic server suddenly stopped working.
I'm running Subsonic serveur (&webapp) on Ubuntu server 64bits with java 1.6.0_24.
When I restart subsonic looks like there is no problems :
$>/etc/init.d/subsonic restart
  * Restarting Subsonic Daemon subsonic
  Started Subsonic [PID 4344, /var/subsonic/subsonic_sh.log]
There is no [Warning] or [Error] infos on the subsonic_sh.log (/var/subsonic/subsonic_sh.log), so i don't understand where does it come from .. (here is my subsonic_sh.log anyway : http://pastebin.com/9VesHBdL)
I tried to figure out what is failing :
- The processus is started :
$> ps aux | grep subsonic
root      4344  100  1.3 1540108 227508 pts/0  Sl   03:43   4:59 java -Xmx150m -Dsubsonic.home=/var/subsonic -Dsubsonic.host=0.0.0.0 -Dsubsonic.port=4040 -Dsubsonic.httpsPort=0 -Dsubsonic.contextPath=/ -Dsubsonic.defaultMusicFolder=/var/music -Dsubsonic.defaultPodcastFolder=/var/music/Podcast -Dsubsonic.defaultPlaylistFolder=/var/playlists -Djava.awt.headless=true -verbose:gc -jar subsonic-booter-jar-with-dependencies.jar
- But it is now broadcasting of the 4040:
$>sudo netstat -lpn | grep :4040
$>sudo lsof -i :4040
I thought my port 4040 should have been blocked, i checked iptables :
$>iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:4040
ACCEPT     udp  --  anywhere             anywhere             udp dpt:4040
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Anyone has an idea of what is happening to my Subsonic server ?
Thanks for your help,
kobhqlt.
kobhqlt
Re: Can't understand why Subsonic stopped working
Postby BKKKPewsey » Fri Sep 07, 2012 1:11 pm
:? Are you saying that you cannot connect to SS using 4040?
Postby kobhqlt » Fri Sep 07, 2012 9:25 pm
No, i'm saying that my subsonic server, which is configured to provide service on port 4040, does not provide anything.
Here is my subsonic.properties file :
#Subsonic preferences.  NOTE: This file is automatically generated.
#Wed Sep 05 20:36:16 CEST 2012
GettingStartedEnabled=false
LicenseCode=XXX
LocaleCountry=
WelcomeSubtitle=
UrlRedirectionEnabled=true
RestTrialExpires-subAir=1314798919030
WelcomeTitle=Nyan Nyan \:3
IndexCreationInterval=1
RestTrialExpires-substream=1314837122889
CoverArtFileTypes=cover.jpg folder.jpg jpg jpeg gif png
FastCacheEnabled=false
VideoTrialExpires=1315105045672
UrlRedirectContextPath=
LocaleVariant=
IndexCreationHour=0
IndexString=A B C D E F G H I J K L M N O P Q R S T U V W X-Z(XYZ)
RestTrialExpires-myapp=1315599129801
LocaleLanguage=fr
LoginMessage=Si vous n'arrivez pas a vous connectez cliquez ici\:\r\n\r\nhttp\://www.youtube.com/watch?v\=BAHtStfZZWg
UrlRedirectFrom=XXX
RestTrialExpires-bologna=1315598147058
SettingsChanged=1345176104038
VideoFileTypes=flv avi mpg mpeg mp4 m4v mkv mov wmv ogv divx m2ts
Theme=coolandclean
IgnoredArticles=The El La Los Las Le Les
MusicFileTypes=mp3 ogg oga aac m4a flac wav wma aif aiff ape mpc shn
LastScanned=1346796466312
Port=4040
PortForwardingEnabled=false
LicenseEmail=XXX
WelcomeMessage2=http\://www.youtube.com/watch?v\=o0Wvn-9BXVc&feature\=related\r\n\r\n\r\n\r\nNever Forget
ServerId=XXX
OrganizeByFolderStructure=true
LicenseDate=1312652584269
UrlRedirectTrialExpires=1314499329533
Shortcuts=New Incoming Podcast
RestTrialExpires-android=1314763031124
As you can see, my SS is configured for port 4040 :
Port=4040
kobhqlt
Postby alphawave7 » Sat Sep 08, 2012 4:17 am
"PortForwardingEnabled=false"
If you connect inside (lan), but not outside (wan), this will be the culprit. Use canyouseeme.org for port 4040 to test, rebooting your router to ensure the port pinhole is working.
Postby kobhqlt » Sat Sep 08, 2012 7:48 pm
Hm, no i'm not connecting from the inside, my subsonic server is running on a distant server.
kobhqlt
Postby kobhqlt » Tue Sep 18, 2012 1:48 am
I still have no idea of what happen with my server. UP.
Thanks for your time.
kobhqlt
