Left-hand pane display only artists (from tags)
Postby Caleb » Sun Sep 09, 2012 12:41 pm
From what I understand, Subsonic 4.73 lets you view your music sorted by the tags, instead of by folders. For some reason I cannot find a way to make the left-hand pane display my media by Artist/Album Artist (it still shows the folders).
Am I missing something?
Caleb
Re: Left-hand pane display only artists (from tags)
Postby cakgok » Mon Sep 10, 2012 8:21 pm
I'm wondering this too, i have no ways to organize the files so id3 based indexing is only thing i want.
It seems the beta have this but i couldn't figure it out.
cakgok
Postby hakko » Mon Sep 10, 2012 8:27 pm
I've built a modded Subsonic server that does this (amongst other things). It might not be what you want since it changes a whole lot of things, but I'll post a link for the record: viewtopic.php?f=8&t=9504
MusicCabinet developer
hakko
Postby cakgok » Mon Sep 10, 2012 8:38 pm
hakko wrote:I've built a modded Subsonic server that does this (amongst other things). It might not be what you want since it changes a whole lot of things, but I'll post a link for the record: viewtopic.php?f=8&t=9504
Oh thanks, but is it possible to use under linux?
cakgok
Postby hakko » Mon Sep 10, 2012 8:50 pm
Yup. Use the stand-alone version from http://dilerium.se/musiccabinet/#installation . Since you're running Linux, I guess you're nerdy enough to get the shell script that starts the subsonic service running.
hakko
Postby txhokie » Sat Sep 22, 2012 11:29 pm
Is this add-on the only way to display only the artists in the left pane? New to Subsonic... my left pane displays all albums as they are in their folders, eg:
Artist A - Album 1
Artist B - Album 2
and I'd like to display only Artist A, and then when I click, it expands somehow to dive down into which album I want. I've seen a bunch of screenshots from others who have their left pane like this, so is everyone using MusicCabinet? I'm definitely open to trying it if that's the best/only way.
txhokie
Postby BKKKPewsey » Sun Sep 23, 2012 11:59 am
You need to have the directory structure as Artist\Album\Tracks.
The left frame will then only display artists - click on one and the centre frame will then display the albums.
Postby hakko » Sun Sep 23, 2012 12:44 pm
But it then displays folder names in the left frame, doesn't it? So artists like "Why?", "The Radio Dept." and other which use reserved file system characters don't get displayed. Or has that been changed in 4.7?
hakko
