Ahhh! HTTP ERROR: 503 SERVICE_UNAVAILABLE
Postby pcs800 » Sun Sep 16, 2012 4:10 am
I upgraded (uhh, yeah) to the latest build/beta and I now get the following
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://
Even when browsing from the server itself.
The service is running, I have rebooted.
Any help?
pcs800
Re: Ahhh! HTTP ERROR: 503 SERVICE_UNAVAILABLE
Postby GJ51 » Sun Sep 16, 2012 6:02 am
Uninstall/reinstall Java.
Postby hakko » Sun Sep 16, 2012 7:45 am
When HTTP ERROR: 503 occurs, have a look at the log files in (Program Files)/Subsonic/log/. There's probably some clue there. Paste it here for feedback.
MusicCabinet developer
hakko
Postby pcs800 » Sun Sep 16, 2012 2:16 pm
Ok here you go
47 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@1415de6: display name [org.springframework.context.support.ClassPathXmlApplicationContext@1415de6]; startup date [Sun Sep 16 10:15:17 EDT 2012]; root of context hierarchy
140 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
765 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@1415de6]: org.springframework.beans.factory.support.DefaultListableBeanFactory@42552c
797 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@42552c: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
828 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: C:\Program Files\Subsonic\subsonic.war
Extracting webapp to c:\subsonic\jetty\3106
890 [main] INFO org.mortbay.log - jetty-6.1.x
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/C:/Program%20Files/Subsonic/subsonic-booter-jar-with-dependencies.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/C:/subsonic/jetty/3106/webapp/WEB-INF/lib/slf4j-log4j12-1.6.1.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
1656 [main] INFO / - Initializing Spring root WebApplicationContext
1656 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
1718 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@7e8c4d: display name [Root WebApplicationContext]; startup date [Sun Sep 16 10:15:19 EDT 2012]; root of context hierarchy
1781 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
1937 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
2000 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-cache.xml]
2047 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@7e8c4d]: org.springframework.beans.factory.support.DefaultListableBeanFactory@19762f
2187 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@19762f: defining beans [playerDao,mediaFileDao,artistDao,albumDao,playlistDao,internetRadioDao,musicFileInfoDao,musicFolderDao,userDao,transcodingDao,podcastDao,avatarDao,shareDao,daoHelper,mediaFileService,securityService,settingsService,mediaScannerService,searchService,networkService,playerService,playlistService,versionService,statusService,musicInfoService,musicIndexService,audioScrobblerService,transcodingService,shareService,podcastService,adService,jukeboxService,metaDataParserFactory,ajaxMultiService,ajaxNowPlayingService,ajaxPlayQueueService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxStarService,ajaxTagService,ajaxTransferService,ajaxChatService,filterChainProxy,httpSessionContextIntegrationFilter,logoutFilter,authenticationProcessingFilter,basicProcessingFilter,restRequestParameterProcessingFilter,basicProcessingFilterEntryPoint,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,exceptionTranslationFilter,basicExceptionTranslationFilter,filterInvocationInterceptor,accessDecisionManager,rememberMeServices,authenticationManager,daoAuthenticationProvider,userCacheWrapper,ldapAuthenticationProvider,bindAuthenticator,userDetailsServiceBasedAuthoritiesPopulator,ajaxServiceInterceptor,ajaxTagServiceSecure,ajaxTransferServiceSecure,cacheFactory,userCache,mediaFileMemoryCache,musicFileMemoryCache]; root of factory hierarchy
2250 [main] INFO org.springframework.jdbc.datasource.DriverManagerDataSource - Loaded JDBC driver: org.hsqldb.jdbcDriver
pcs800
Postby hakko » Sun Sep 16, 2012 2:56 pm
Does it just stop after that? Then I'm lost, sorry. The only thing that comes to mind is increasing memory but I dunno, there's no indication here of what's happening at all.
hakko
Postby pcs800 » Sun Sep 16, 2012 3:05 pm
That one did stop after that, but now that i have let it run for a few minutes, here's a new log in two posts because it won't let me put it all in one.
197218 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@19762f: defining beans [playerDao,mediaFileDao,artistDao,albumDao,playlistDao,internetRadioDao,musicFileInfoDao,musicFolderDao,userDao,transcodingDao,podcastDao,avatarDao,shareDao,daoHelper,mediaFileService,securityService,settingsService,mediaScannerService,searchService,networkService,playerService,playlistService,versionService,statusService,musicInfoService,musicIndexService,audioScrobblerService,transcodingService,shareService,podcastService,adService,jukeboxService,metaDataParserFactory,ajaxMultiService,ajaxNowPlayingService,ajaxPlayQueueService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxStarService,ajaxTagService,ajaxTransferService,ajaxChatService,filterChainProxy,httpSessionContextIntegrationFilter,logoutFilter,authenticationProcessingFilter,basicProcessingFilter,restRequestParameterProcessingFilter,basicProcessingFilterEntryPoint,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,exceptionTranslationFilter,basicExceptionTranslationFilter,filterInvocationInterceptor,accessDecisionManager,rememberMeServices,authenticationManager,daoAuthenticationProvider,userCacheWrapper,ldapAuthenticationProvider,bindAuthenticator,userDetailsServiceBasedAuthoritiesPopulator,ajaxServiceInterceptor,ajaxTagServiceSecure,ajaxTransferServiceSecure,cacheFactory,userCache,mediaFileMemoryCache,musicFileMemoryCache]; root of factory hierarchy
197218 [main] ERROR org.springframework.web.context.ContextLoader - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'mediaFileService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'metaDataParserFactory' while setting bean property 'metaDataParserFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'metaDataParserFactory' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot create inner bean 'net.sourceforge.subsonic.service.metadata.FFmpegParser#19ba640' of type [net.sourceforge.subsonic.service.metadata.FFmpegParser] while setting bean property 'parsers' with key [1]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.sourceforge.subsonic.service.metadata.FFmpegParser#19ba640' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'transcodingService' while setting bean property 'transcodingService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transcodingService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'playerService' while setting bean property 'playerService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: User not found: SA
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:275)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:131)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher$2.run(Unknown Source)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'metaDataParserFactory' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot create inner bean 'net.sourceforge.subsonic.service.metadata.FFmpegParser#19ba640' of type [net.sourceforge.subsonic.service.metadata.FFmpegParser] while setting bean property 'parsers' with key [1]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.sourceforge.subsonic.service.metadata.FFmpegParser#19ba640' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'transcodingService' while setting bean property 'transcodingService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transcodingService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'playerService' while setting bean property 'playerService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: User not found: SA
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:230)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:117)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveManagedList(BeanDefinitionValueResolver.java:287)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:126)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
... 59 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.sourceforge.subsonic.service.metadata.FFmpegParser#19ba640' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'transcodingService' while setting bean property 'transcodingService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transcodingService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'playerService' while setting bean property 'playerService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: User not found: SA
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:219)
... 74 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transcodingService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'playerService' while setting bean property 'playerService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: User not found: SA
... 82 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: User not found: SA
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1338)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
... 95 more
Caused by: org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: User not found: SA
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:577)
at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:71)
at net.sourceforge.subsonic.dao.PlayerDao.deleteOldPlayers(PlayerDao.java:132)
at net.sourceforge.subsonic.service.PlayerService.init(PlayerService.java:53)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1414)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1375)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1335)
... 105 more
Caused by: java.sql.SQLException: User not found: SA
at java.sql.DriverManager.getConnection(Unknown Source)
... 119 more
197234 [main] ERROR org.mortbay.log - Failed startup of context org.mortbay.jetty.webapp.WebAppContext@e2d0b2{/,jar:file:/C:/Program%20Files/Subsonic/subsonic.war!/}
pcs800
... 59 more
... 74 more
... 82 more
... 95 more
... 105 more
... 119 more
197250 [main] WARN org.mortbay.log - Nested in org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'mediaFileService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'metaDataParserFactory' while setting bean property 'metaDataParserFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'metaDataParserFactory' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot create inner bean 'net.sourceforge.subsonic.service.metadata.FFmpegParser#19ba640' of type [net.sourceforge.subsonic.service.metadata.FFmpegParser] while setting bean property 'parsers' with key [1]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.sourceforge.subsonic.service.metadata.FFmpegParser#19ba640' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'transcodingService' while setting bean property 'transcodingService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transcodingService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'playerService' while setting bean property 'playerService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: User not found: SA:
197578 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:90
Subsonic running on: http://localhost:90/
197922 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
199031 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
199156 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[198.111.223.46:9412](local),objID:[0:0:0, 0]]]]
pcs800
Postby hakko » Sun Sep 16, 2012 3:27 pm
If you stop the subsonic service and check C:/subsonic/db/subsonic.script, does it contain the line
CREATE USER SA PASSWORD ""
mine looks like
ALTER TABLE SHARE_FILE ALTER COLUMN ID RESTART WITH 0
ALTER TABLE TRANSCODING2 ALTER COLUMN ID RESTART WITH 2
GRANT DBA TO SA
SET WRITE_DELAY 10
SET SCHEMA PUBLIC
INSERT INTO VERSION VALUES(1)
INSERT INTO VERSION VALUES(2)
INSERT INTO VERSION VALUES(3)
we're out in the wild here but if you're missing that line, you could try making backups, edit subsonic.script and add the CREATE USER SA PASSWORD "" and GRANT DBA TO SA before the first INSERT INTO line, restart and see if it helps.
first google hit for the error message: http://www.techcrony.info/2009/06/02/ni ... -found-sa/
hakko
Postby pcs800 » Sun Sep 16, 2012 3:36 pm
Here are the entire contents of that file
CREATE SCHEMA PUBLIC AUTHORIZATION DBA
SET WRITE_DELAY 10
pcs800
Postby hakko » Sun Sep 16, 2012 3:38 pm
That doesn't sound too good to me. I guess I'd remove the entire C:/subsonic directory and try installing again. I think the Subsonic 4.7 installer makes backups before overwriting everything if you need to go back to your previous settings as well?
hakko
Postby pcs800 » Sun Sep 16, 2012 3:46 pm
I have daily clones of the entire hard drive, i will go back a month or so and pull the whole directory back from there and see if it makes a difference.
pcs800
Postby pcs800 » Sun Sep 16, 2012 4:18 pm
I pulled that subsonic.script file from about a month ago and now everything works fine. Would be nice to know what caused it though.
pcs800
Postby hakko » Sun Sep 16, 2012 4:40 pm
Good to hear it's working and that you take backups seriously. Personally I just don't trust HSQLDB for production systems. I understand why Sindre has chosen it, but I feel like I'm avoiding so many head-aches by going with PostgreSQL. Plus that the version he uses is six years old? mumble mumble.
hakko
Postby pcs800 » Sun Sep 16, 2012 5:41 pm
Yes I maintain many servers and worked in Government IT for 10 years, so backups are a given in my book. Anyone who runs any device without a means of recovering data, is asking for trouble.
pcs800
Postby GJ51 » Sun Sep 16, 2012 6:28 pm
i always back up my backups. :mrgreen:
With WHS 2011 going for $50 there's no reason not to have automated backups on a Windows network.
