Jetty Crashing on 4.7
Postby kingzain74 » Mon Sep 24, 2012 8:01 am
been using subsonic for a few years now and never had a single issue with it ever now that i updated to 4.7 the Jetty is not working and im getting the
" HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://
error when running subsonic , iv tried going back to 4.6 and even 4.5 with no luck , reinstalled the newest java update also to no luck , is this a common issue n it is fixable ?
win 7 64-bit pro
kingzain74
Re: Jetty Crashing on 4.7
Postby krantul » Mon Sep 24, 2012 12:24 pm
Same issue.
Log just says:
[2012-09-24 08:21:33,625] INFO DaoHelper - Checking database schema.
[2012-09-24 08:21:33,996] INFO DaoHelper - Done checking database schema.
[2012-09-24 08:21:34,049] INFO VersionService - Resolved local Subsonic version to: 4.7
[2012-09-24 08:21:34,193] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Tue Sep 25 03:00:00 EDT 2012
[2012-09-24 08:21:37,380] INFO NetworkService - Deleted port mapping for port 4040
krantul
Postby hakko » Mon Sep 24, 2012 6:12 pm
When HTTP ERROR: 503 occurs, have a look at the log files in (Program Files)/Subsonic/log/. There's probably some clue there. Paste it here for feedback.
MusicCabinet developer
hakko
Postby kingzain74 » Wed Sep 26, 2012 3:28 am
[2012-09-25 23:23:41,228] INFO DaoHelper - Checking database schema.
[2012-09-25 23:23:42,757] INFO Schema25 - Database table 'version' not found. Creating it.
[2012-09-25 23:23:43,303] ERROR DaoHelper - Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: error in script file line: 59 S1000 General error java.lang.NullPointerException in statement [SET TABLE MEDIA_FILE INDEX'397222344 397790104 397790104 343171040 392322744 398971960 352512000 352420624 397222344 372963416 350691760 396692400 352285896 50265']
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:382)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:429)
at net.sourceforge.subsonic.dao.schema.Schema25.execute(Schema25.java:36)
at net.sourceforge.subsonic.dao.DaoHelper.checkDatabase(DaoHelper.java:110)
at net.sourceforge.subsonic.dao.DaoHelper.<init>(DaoHelper.java:67)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:131)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher$2.run(Unknown Source)
Caused by: java.sql.SQLException: error in script file line: 59 S1000 General error java.lang.NullPointerException in statement [SET TABLE MEDIA_FILE INDEX'397222344 397790104 397790104 343171040 392322744 398971960 352512000 352420624 397222344 372963416 350691760 396692400 352285896 50265']
at java.sql.DriverManager.getConnection(Unknown Source)
... 82 more
[2012-09-25 23:23:44,114] INFO VersionService - Resolved local Subsonic version to: 4.7
this the log ?
kingzain74
Postby hakko » Wed Sep 26, 2012 6:09 am
That's the log. I think you should report this to Sindre, it's another in a pretty long row of database related errors. My personal solution to this was to stop using HSQLDB as main database but that's not really an option for everyone.
hakko
Postby BKKKPewsey » Wed Sep 26, 2012 12:15 pm
See viewtopic.php?f=2&t=10326
Looks like the same/similar issue.
Postby Boutros » Wed Sep 26, 2012 4:04 pm
Yeah, I got the same issue this morning - like BKKKPewsey, mine manifested several days after I did the upgrade.
What's weird is that I did a fresh install - I uninstalled 4.6, uninstalled Java 6, deleted the C:/subsonic folder, then installed Java 7, and, finally, SS 4.7. Weird...
Boutros
Postby GJ51 » Wed Sep 26, 2012 6:35 pm
I'm not sure what's going on but I installed 4.7 final WAR version on Win 2k8R2 and it ran fine until I implemented SSL on Tomcat. It ran fine last night - then this morning it went belly up. When I clicked on the link to open it in Chrome it just downloaded a file named "download" and didn't do anything else. I could log into Tomcat root ok both through http and https for a while, then Tomcat just gave up and quit loading and I can't get it to start anymore.
Oddly, I have the latest Madsonic mod running fine on the same server in a VM with the same setup.
Enough to drive a Saint crazy - and for sure, I'm no Saint.
Users browsing this forum: Google [Bot] and 20 guests
