User statistics
User statistics
Postby mjeppo » Tue Sep 25, 2012 6:18 pm
Is there any way to put the statistics back on top of the left panel instead of at the bottom? :?:
10.208 artiesten
18.122 albums
256.040 songs
1978,94 GB
18.131 uren
9.445 artiesten
21.140 albums
342.780 songs
14998,37 GB
28.673 uren
mjeppo
Re: User statistics
Postby hakko » Tue Sep 25, 2012 6:22 pm
Search for the file left.jsp, open it with a text editor and move the stats part to where you want it.
MusicCabinet developer
hakko
Re: User statistics
Postby mjeppo » Tue Sep 25, 2012 6:34 pm
But there seem to be 3 versions of left.jsp, in 3 seperate folders (2583, 3081and 3106) in the jetty folder. Which one should I modify? Or should I modify all 3 of them?
9.445 artiesten
21.140 albums
342.780 songs
14998,37 GB
28.673 uren
mjeppo
Re: User statistics
Postby mjeppo » Tue Sep 25, 2012 6:42 pm
Well, i had a look at the jsp file, but since I don't know the first thing about scripting I would appreciate a more "dummy-proof" explanation... :? :P
9.445 artiesten
21.140 albums
342.780 songs
14998,37 GB
28.673 uren
mjeppo
Re: User statistics
Postby hakko » Tue Sep 25, 2012 7:10 pm
2583 and 3081 are reminiscent from previous versions that you have installed. those directories are safe to remove.
hakko
Re: User statistics
Postby mjeppo » Tue Sep 25, 2012 8:09 pm
Well, after some fiddling around I managed to get if fixed. Thanks.
:lol:
9.445 artiesten
21.140 albums
342.780 songs
14998,37 GB
28.673 uren
mjeppo
