Weird Issue with various artist in album view.
Postby pir8radio » Fri Sep 28, 2012 9:38 pm
there seems to be a bug... When i search for an album that has various artists subsonic separates them so each track appears to be a different album! i think subsonic is doing this based on ARTIST instead of ALBUM ARTIST so instead of grouping "ALBUM NAME - VARIOUS ARTISTS" as one album its taking "ALBUM NAME - TRACK ARTIST" and posting them as separate albums. see below image. This should be an easy fix..
pir8radio
Re: FOUND BUG ON 4.7
Postby BKKKPewsey » Fri Sep 28, 2012 11:46 pm
pir8radio wrote:This should be an easy fix..
It may be if it was reproducible - np on my set-up :?
However I noticed that your stats are showing 30k+ albums and only 115k tracks so either you have a lot of eps and singles
OR there is something wrong with either your tagging or folder structure as far as SS is concerned.
Postby pir8radio » Sat Sep 29, 2012 2:50 am
Yea im not good at acquiring full albums. i have lots of one hit wonders from every album out there... Think you can help with the full albums? :wink: JK... or not?
Ok i will try to rename this subject..... so not to scare anyone, and triple check my stuff... but when i load the same files in things like zune and itunes they group correctly... sooooo i dunno....
Hey what add-on do you use for your now playing tag, is that just the regular mod thats been out there forever?
pir8radio
Re: Weird Issue with various artist in album view.
Postby BKKKPewsey » Sun Sep 30, 2012 11:39 pm
pir8radio wrote:Hey what add-on do you use for your now playing tag, is that just the regular mod thats been out there forever?
Not sure what you mean :? The graphic is linked to my last FM acc
Postby pir8radio » Mon Oct 01, 2012 3:40 pm
Oh... Yea... i found the website (maybe yours) that allows you to put your last.fm username in and create that image... i thought it was directly from your subsonic.
pir8radio
