4.7 Podcast Issue
4.7 Podcast Issue
Postby cgeek5467 » Mon Oct 01, 2012 10:19 am
I've been having an issue for a podcast "No Agenda Show" http://feed.nashownotes.com/rss.xml .
The show files are downloaded. I see them on the disk. I see that they are the proper size. I can play them using vlc.
However, in subsonic, the file will appear corrupt or incomplete. Sometimes subsonic thinks the file size is 0. Other times it will think that the file is there but only partial -- meaning instead of showing it to be a 2 hour show, it appears to be 20 minutes or something like that.
I do not see an error messages in subsonic logs.
It usually occurs with the last podcast downloaded.
I can "fix" the problem by shutting down subsonic and then starting it again.
I've not noticed it with other podcasts, but I only subscribe to a few and not all of them update frequently.
I've downgraded to 4.6 and do not have the issue. I never saw this when I had been running 4.6 previously.
I updated to 4.7 final two weeks ago.
Is there some troubleshooting I can do to capture information for you on the issue in 4.7?
Thanks, Mike
cgeek5467
Re: 4.7 Podcast Issue
Postby BKKKPewsey » Mon Oct 01, 2012 1:24 pm
I think giving the link should give Sindre enough info to troubleshoot.
It must be something in the way those files are tagged which is causing 4.7 issues. :(
Postby elvosparsley » Thu Oct 11, 2012 12:21 pm
I'm having the same problem with any of the BBC podcasts.
I did have 4.7 beta 3 running on ClearOS 5.2, where they downloaded ok but would not play.
I had to remove beta 3 and install 4.7 stable as I had trouble upgrading.
The beat 3 podcasts then played but any post 4.7 stable downloads do not with the file size showing as around 30-40k when they're actually around 19 Meg.
elvosparsley
Users browsing this forum: Bing [Bot] and 22 guests
