UTF-8 - can't get it to work
Postby Sykh » Tue Oct 02, 2012 7:20 am
Hey all,
yes i've used the search and i found a solution but i couldnt get it to work :(
I'm running Ubuntu 12.04.1 LTS
Everything done as root:
locale
LANG=de_DE.UTF-8
LANGUAGE=de_DE
LC_CTYPE="de_DE.UTF-8"
LC_NUMERIC="de_DE.UTF-8"
LC_TIME="de_DE.UTF-8"
LC_COLLATE="de_DE.UTF-8"
LC_MONETARY="de_DE.UTF-8"
LC_MESSAGES="de_DE.UTF-8"
LC_PAPER="de_DE.UTF-8"
LC_NAME="de_DE.UTF-8"
LC_ADDRESS="de_DE.UTF-8"
LC_TELEPHONE="de_DE.UTF-8"
LC_MEASUREMENT="de_DE.UTF-8"
LC_IDENTIFICATION="de_DE.UTF-8"
LC_ALL=
If i list a folder everything returns okay, so i guess the locales are installed and running correctly
Trentemöller# ll
insgesamt 32
drwxrwxrwx   6 subsonic subsonic  4096 Jul 31 18:33 ./
drwxrwxr-x 202 subsonic subsonic 12288 Sep 28 21:17 ../
drwxrwxrwx   2 subsonic subsonic  4096 Aug 23 18:19 Late Night Tales/
drwxrwxrwx   2 subsonic subsonic  4096 Aug 23 18:19 Moan (Vinyl)/
drwxrwxrwx   2 subsonic subsonic  4096 Aug 23 18:19 The Last Resort/
drwxrwxrwx   2 subsonic subsonic  4096 Aug 23 18:19 The Trentemøller Chronicles/
But in subsonic if it's a folder it won't show up (figures) and filenames are with ??? and won't play.
I've edited /etc/default/subsonic and added
export LANG=de_DE.UTF-8
which should do the trick...but it doesn't.
Can someone please point me in the right direction?
Thanks in advance!
Sykh
Re: UTF-8 - can't get it to work
Postby BKKKPewsey » Tue Oct 02, 2012 10:35 am
And your SS version is? :?
Postby Sykh » Tue Oct 02, 2012 6:34 pm
Aww i knew i forgot something
Version 4.7 (build 3105) – 11. September 2012
Sykh
Postby hakko » Tue Oct 02, 2012 7:08 pm
In my start script, I have
export LC_ALL="sv_SE.UTF-8"
export LANG="sv_SE.UTF-8"
java -Dfile.encoding=UTF8 [...]
MusicCabinet developer
hakko
Postby BKKKPewsey » Tue Oct 02, 2012 7:39 pm
Also for SS 4.7 which uses the tags much more then previous versions you need to make sure your tags are also UTF8.
See viewtopic.php?f=3&t=10216#p45535
