Internal Error, subsonic crashed! I need help!!!
Postby rickyboby » Sun Oct 07, 2012 11:56 am
ic encountered an internal error. You can report this error in the Subsonic Forum. Please include the information below.
Message PreparedStatementCallback; SQL [select top 1 id from artist where not present]; S1000 General error java.lang.NullPointerException in statement [select top 1 id from artist where not present]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [select top 1 id from artist where not present]
Java version Sun Microsystems Inc. 1.6.0_35
Server jetty-6.1.x
Memory Used 53 of 96 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select top 1 id from artist where not present]; S1000 General error java.lang.NullPointerException in statement [select top 1 id from artist where not present]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [select top 1 id from artist where not present] at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:106) at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:72) at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:80) at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:80) at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:607) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:641) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:670) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:678) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:710) at org.springframework.jdbc.core.JdbcTemplate.queryForList(JdbcTemplate.java:768) at net.sourceforge.subsonic.dao.AbstractDao.queryForInt(AbstractDao.java:97) at net.sourceforge.subsonic.dao.ArtistDao.expunge(ArtistDao.java:128) at net.sourceforge.subsonic.controller.MusicFolderSettingsController.expunge(MusicFolderSettingsController.java:71) at net.sourceforge.subsonic.controller.MusicFolderSettingsController.formBackingObject(MusicFolderSettingsController.java:56) at org.springframework.web.servlet.mvc.AbstractFormController.getErrorsForNewForm(AbstractFormController.java:358) at org.springframework.web.servlet.mvc.AbstractFormController.showNewForm(AbstractFormController.java:338) at org.springframework.web.servlet.mvc.AbstractFormController.handleRequestInternal(AbstractFormController.java:278) at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:807) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServle
Can anyone read this???????????????????????? :twisted:
rickyboby
Re: Internal Error, subsonic crashed! I need help!!!
Postby hakko » Sun Oct 07, 2012 12:36 pm
Looks like another database issue to look into for Sindre. I haven't seen it before at least. sindre@activeobjects.no
If this would force you to re-install, check viewtopic.php?f=6&t=10338
MusicCabinet developer
hakko
Postby Boutros » Mon Oct 08, 2012 6:16 pm
I'm getting what looks to be much the same thing. This is the second total crash I've had in a week (had to do a fresh install and re-create all my users last time). Thus far, for me, 4.7 is... not awesome.
Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]
Java version Oracle Corporation 1.7.0_07
Server jetty-6.1.x
Memory Used 59 of 225 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:120)
at net.sourceforge.subsonic.dao.MediaFileDao.getMediaFile(MediaFileDao.java:58)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:103)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:79)
at net.sourceforge.subsonic.controller.NowPlayingController.handleRequestInternal(NowPlayingController.java:54)
Caused by: java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]
... 63 more
Boutros
