Testing on Linux
Testing on Linux
Postby Ikyo » Fri Jan 18, 2008 7:09 am
I am looking for some songs in the following formats to test on a Linux machine to get a transcode pack setup for Linux users. I am needing:
.ape
.shn
.ofr
.mpc
Let me know if you can supply me with something in those formats. I have put up the wma working example so far. Thanks in advance for the help.
Ikyo
Postby sindre_mehus » Fri Jan 18, 2008 8:10 pm
Thanks a lot for your effort!
I've put some example files here:
http://www.activeobjects.no/tmp/06-hamb ... ess_ex.ape
http://www.activeobjects.no/tmp/07-put_ ... ess_ex.ofr
http://www.activeobjects.no/tmp/04-leav ... dio_ex.mpc
Pls let me know when you've downloaded them, so I can remove them again.
Cheers,
Postby Ikyo » Mon Feb 04, 2008 6:37 pm
You can remove them now.
Ikyo
Postby Ikyo » Mon Feb 04, 2008 6:45 pm
I was able to verify that my script will also work for .ofr files. I am going to do some checking on the .ape. I have switched to running everything on a Mac OSX machine because it is a lot smaller and tons of less noise. I will update as soon as I find out more.
Ikyo
Users browsing this forum: No registered users and 71 guests
