caching or other issue
Re: caching or other issue
Postby hakko » Thu Oct 11, 2012 12:29 pm
I'm pretty sure this has been reported before for the 4.7 media scanner.
MusicCabinet developer
hakko
Postby GJ51 » Thu Oct 11, 2012 5:26 pm
Go to Settings.
Click on "Clean-up database" at the bottom of the main panel. Rescan.
If that doesn't fix it. Uncheck the folder with the errors and Save. Rerun clean db then rescan. Then recheck the "Enabled" box on the folder and rescan.
Postby bushman4 » Thu Oct 11, 2012 6:37 pm
Then uncheck the media share that contains that folder.
Then save.
Then clean-database.
Then Scan (even if that was the only media folder you had originally...)
then recheck Enable on that media folder.
Then save.
Then rescan.
(Basically.... "What HE said...")
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Users browsing this forum: Bing [Bot] and 21 guests
