Subsonic automaticly take the full window
Postby lunarok » Sun Oct 14, 2012 12:37 pm
I have look for informations but nothing comes out of my researchs.
There is my problem : if you have a divided page and in a part link subsonic url, when the page comes, it's reloading itself to take the full window making disappear the top bar for exemple.
Well, it's annoying because for exemple I use Yunohost to have a portal to all my applications.
I integrate inside all additionnal applications I use that are not inside Yunohost project for now. Everything is working fine (Transmission, Sickbeard and XBMC for exemples) unless Subsonic. Subsonic always make the topbar (navigation between the applications) disappear.
Any idea ? a parameter to fix this ?
Cédric
lunarok
Re: Subsonic automaticly take the full window
Postby hakko » Sun Oct 14, 2012 1:38 pm
Search for the file index.jsp in C:/subsonic
Open it, and remove this part:
    <script type="text/javascript">
        if (window != window.top) {
            top.location.href = location.href;
    </script>
Does it work better?
MusicCabinet developer
hakko
Postby lunarok » Sat Dec 15, 2012 1:47 pm
Sorry I don't see this before.
It's working now in frame mode. But I get another issue with player complaintly useless if subsonic is in frame. I think it's related to the fact he is himless creating frame and a loss of arrow or something.
I open a new subject for this here :
viewtopic.php?f=2&t=10971
lunarok
