Subsonic for Android Registration
Postby SmplyUnprdctble » Thu Oct 18, 2012 11:23 pm
I'm curious how the Android Ad-Free side works.
I have two Android devices (both under the same Google Play account) and would prefer not to have to spend the couple bucks twice to register Subsonic for Android (much less again in the future when I get my next device).
How does this registration process work? Do you get a License Key you need to enter somewhere? Do you get a key file you need to put somewhere? Is something magically attached to your account somewhere?
I personally think having a "Registration App" in the Play Store (or even a paid vs free app) would be the less confusing way to go.
SmplyUnprdctble
Re: Subsonic for Android Registration
Postby alphawave7 » Fri Oct 19, 2012 4:32 am
I paid for the new app today, and it applied to other devices WHEN I UPDATED THEM afterwards. IF it doesn't seem to work initially, remove the app entirely from your device, and re-download/install. That should fix it. Cheers!
