Clean-up database error
Postby gothax » Sat Oct 20, 2012 6:14 pm
Problem Description: I saw that some directory are not seen so i want clean my database but i receve this error (with the function Clean-up database)
Troubleshooting Steps: nothing :-(
Playback Application and version: opera / chromium
Subsonic Version: Version 4.7 (build 3105) – 11 septembre 2012
Server Version: jetty-6.1.x, java 1.6.0_34, Linux (67,8 MB / 87,7 MB)
Hardware Platform: Synology NAS 411Slim
Java Memory Limit: no
Problem Filename: no
Output from ffmpeg -i: no
Last ten log file lines:
Subsonic encountered an internal error. You can report this error in the Subsonic Forum. Please include the information below. Exception   org.springframework.dao.TransientDataAccessResourceException
Message   PreparedStatementCallback; SQL [select top 1 id from album where not present]; S1000 General error java.util.NoSuchElementException in statement [select top 1 id from album where not present]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select top 1 id from album where not present]
Java version   Sun Microsystems Inc. 1.6.0_34
Operating system   Linux 2.6.32.12
Server   jetty-6.1.x
Memory   Used 51 of 87 MB
Stack trace   org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select top 1 id from album where not present]; S1000 General error java.util.NoSuchElementException in statement [select top 1 id from album where not present]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select top 1 id from album where not present]
   at org.springframework.jdbc.core.JdbcTemplate.queryForList(JdbcTemplate.java:768)
   at net.sourceforge.subsonic.dao.AbstractDao.queryForInt(AbstractDao.java:97)
   at net.sourceforge.subsonic.dao.AlbumDao.expunge(AlbumDao.java:203)
   at net.sourceforge.subsonic.controller.MusicFolderSettingsController.expunge(MusicFolderSettingsController.java:72)
   at net.sourceforge.subsonic.controller.MusicFolderSettingsController.formBackingObject(MusicFolderSettingsController.java:56)
   at org.springframework.web.servlet.mvc.AbstractFormController.getErrorsForNewForm(AbstractFormController.java:358)
   at org.springframework.web.servlet.mvc.AbstractFormController.showNewForm(AbstractFormController.java:338)
   at org.springframework.web.servlet.mvc.AbstractFormController.handleRequestInternal(AbstractFormController.java:278)
   at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:227)
   at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:626)
Caused by: java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select top 1 id from album where not present]
   ... 66 more
gothax
Re: Clean-up database error
Postby hakko » Sat Oct 20, 2012 7:43 pm
There are active, unsolved bug reports for Subsonic 4.7 just like yours. Most of them boil down to some bug in the 4.7 media scanner that makes newly added artists/albums sometimes not appear, and to the fact that Subsonic 4.7 uses an almost ancient database that was released 2006-09-27, which in turn has known bugs.
As there's no bug tracker, I guess the best option is to send bug reports to Sindre: sindre@activeobjects.no
MusicCabinet developer
hakko
Postby gothax » Sat Oct 20, 2012 8:10 pm
Oki thx hakko ;)
gothax
Users browsing this forum: Bing [Bot] and 21 guests
