Upload to Server
Upload to Server
Postby charlie14 » Sun Oct 21, 2012 1:49 pm
It is possible for the "Incoming" folder on the upload its own folder on the server do. Where is the set permanently?
This setting should cannot be changed.
charlie14
Re: Upload to Server
Postby BKKKPewsey » Mon Oct 22, 2012 1:01 pm
Without modding the easiest way is enter the folder that you want to upload to as the first entry in settings/media folders.
For some reason that only the dev can answer SS will always default to the first entry.
