Certain artist pages give errors.
Postby frag24 » Fri Oct 26, 2012 5:25 pm
Subsonic Version: 4.7 (build 3132SE) – September 26, 2012 – (Moded by MadEvil)
Server Version: jetty-6.1.x, java 1.6.0_34, Linux (98.3 MB / 160.8 MB)
Hardware Platform: NAS, Synology DS1512+
I'm using the SS synology package found here: http://www.eg-blog.de/?p=566 and have the Java SE for embedded 6 package installed as well.
Problem Description: I'm a new user, this is my first install of SS. It works fine for most of the artists in my library, and I can stream to remote networks just fine. However, when trying to view some artists in the left hand panel, it will either give me the error at the bottom of this post, or simply a page stating:
Not found
Sorry, we could not find what you were looking for.
Try reloading the web page. If that doesn't help, try scanning the media folders again."
This only happens on <10% of the artists in my library, and I haven't found any common link like a special character in the name or anything. Another cosmetic problem, which may or may not be related, is in the upper portion of the left panel, where it lists the statistics about your library, it show that I have 0 artists, 0 albums, and 2 songs. This information is inaccurate, and I believe I have more than 1300 artists, and >30k songs. The first time I loaded my library, these numbers in the upper left seemed to correctly reflect my actual library values as it was counting all the files. Once the first scan finished though, now it shows these incorrect numbers.
Troubleshooting Steps: I've tried refreshing the media library, which I can't tell if that is actually doing anything. The left panel just refreshes after a second, with no change in the issue. I've also tried refreshing the library through the settings menu, and it states that it is refreshing, which could take several minutes, but I also see no change in either the cosmetic issue, or the error pages I see on certain artists. Not sure what else to try, anyone have any suggestions?
Error message from the artists that give one:
Exception   org.springframework.dao.TransientDataAccessResourceException
Message   PreparedStatementCallback; SQL [update media_file set folder=?,type=?,override=?,format=?,title=?,album=?,album_name=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,override=?,format=?,title=?,album=?,album_name=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,override=?,format=?,title=?,album=?,album_name=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
Java version   Sun Microsystems Inc. 1.6.0_34
Operating system   Linux 3.2.11
Server   jetty-6.1.x
Memory   Used 75 of 160 MB
Stack trace   org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [update media_file set folder=?,type=?,override=?,format=?,title=?,album=?,album_name=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,override=?,format=?,title=?,album=?,album_name=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,override=?,format=?,title=?,album=?,album_name=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
   at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:71)
   at net.sourceforge.subsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:136)
   at net.sourceforge.subsonic.service.MediaFileService.updateChildren(MediaFileService.java:387)
   at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:220)
   at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:201)
   at net.sourceforge.subsonic.controller.MainController.handleRequestInternal(MainController.java:84)
   at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
   at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
   at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:227)
   at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:626)
Caused by: java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,override=?,format=?,title=?,album=?,album_name=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
   ... 63 more
frag24
Re: Certain artist pages give errors.
Postby BKKKPewsey » Fri Oct 26, 2012 6:21 pm
When you start to scan the media folders, check the log
You should see something like
[10/26/12 3:09:43 PM BST]   INFO   MediaScannerService   Scanned media library with 133000 entries.
[10/26/12 3:09:48 PM BST]   INFO   MediaScannerService   Scanned media library with 133174 entries.
[10/26/12 3:09:48 PM BST]   INFO   MediaScannerService   Marking non-present files.
[10/26/12 3:10:44 PM BST]   INFO   MediaScannerService   Marking non-present artists.
[10/26/12 3:10:45 PM BST]   INFO   MediaScannerService   Marking non-present albums.
[10/26/12 3:10:47 PM BST]   INFO   MediaScannerService   Completed media library scan.
Do you?
If not and all you see are errors then it would seem your DB is corrupted
Stop SS and delete the ./subsonic/DB folder then restart SS and rescan folders
Postby hakko » Fri Oct 26, 2012 6:45 pm
The reason of this is a bad database choice by Sindre. To not lose all of your settings, read this topic before doing a totally clean install: viewtopic.php?f=6&t=10338
MusicCabinet developer
hakko
Postby frag24 » Fri Oct 26, 2012 7:40 pm
In the log it would simply state that the media scan failed. I just went ahead and reinstalled the entire application, since I hadn't modified many settings at all.
Haven't seen the problem again yet... hopefully that stays.
frag24
Users browsing this forum: Bing [Bot] and 22 guests
