Failed to create thumbnail for 2 albums [Resolved]
Postby fuzzbomb » Wed Oct 31, 2012 5:47 am
So I've seen a few other people with thumbnail problems, but none like this. They seem to be having problems with a lot of thumbnails, I'm only having problems with 2.
2 albums, on 2 different servers. The same 2 albums. I downloaded cover art for them through the Subsonic search, and every time those albums show up they have no thumbnail and this message is in the log:
WARN   CoverArtController   Failed to create thumbnail for /data/[user]/Media/iTunes/Music/Amy Ray/Lung of Love/cover.jpg
WARN   CoverArtController   Failed to create thumbnail for /data/[user]/Media/iTunes/Music/Greevace/The Eye Sees All/cover.jpg
Like I said, same 2 albums, on 2 different servers.
Both are FreeBSD 9.0, Subsonic 4.7. One is running the standalone, and one is running under Tomcat 6.
Tried moving the album directories, rescanning, cleaning database, moving back, rescanning. Same thing.
Anybody got any ideas?
fuzzbomb
Re: Failed to create thumbnail for 2 albums
Postby hakko » Wed Oct 31, 2012 6:27 am
Replace the cover art, your java jpeg codec might just not handle them well.
MusicCabinet developer
hakko
Postby fuzzbomb » Wed Oct 31, 2012 2:55 pm
hakko wrote:Replace the cover art, your java jpeg codec might just not handle them well.
I tried that, also tried embedding the art (downloaded a different file from the folder.jpg that I was using) into the files, too. No go.
fuzzbomb
Postby GJ51 » Wed Oct 31, 2012 7:08 pm
Try the same procedure as when music isn't showing properly.
Settings - Music folders - uncheck all "Enabled" boxes - Save
Click "Scan media folders now"
Click "Clean-up database"
re-check "Enabled" boxes
rescan folders
Postby fuzzbomb » Thu Nov 01, 2012 7:17 pm
rescan folders
Hey that worked, thanks!
fuzzbomb
Users browsing this forum: Bing [Bot] and 21 guests
