Error
Error
Postby drmaq » Fri Feb 08, 2008 2:57 am
this the error that i got when i tried to access my albums
Exception java.lang.OutOfMemoryError
Message Java heap space
Java version Sun Microsystems Inc. 1.6.0_03
Operating system Windows XP 5.1
Server jetty-6.1.x
Memory Used 11 of 11 MB
Stack trace java.lang.OutOfMemoryError: Java heap space at org.apache.jasper.compiler.JDTCompiler$1CompilationUnit.getContents(JDTCompiler.java:114) at org.eclipse.jdt.internal.compiler.parser.Parser.parse(Parser.java:8639) at org.eclipse.jdt.internal.compiler.parser.Parser.parse(Parser.java:8621) at org.eclipse.jdt.internal.compiler.parser.Parser.dietParse(Parser.java:7420) at org.eclipse.jdt.internal.compiler.Compiler.beginToCompile(Compiler.java:289) at org.eclipse.jdt.internal.compiler.Compiler.compile(Compiler.java:315) at org.apache.jasper.compiler.JDTCompiler.generateClass(JDTCompiler.java:399) at org.apache.jasper.compiler.Compiler.compile(Compiler.java:297) at org.apache.jasper.compiler.Compiler.compile(Compiler.java:276) at org.apache.jasper.compiler.Compiler.compile(Compiler.java:264) at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:563) at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:303) at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314) at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264) at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487) at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:362) at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216) at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181) at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:712) at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405) at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:268) at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:126) at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:167) at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:239) at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1158) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:900) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:808) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:476) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:431) at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
drmaq
Postby jigsaw » Mon Feb 11, 2008 9:02 pm
Maybe you are allocating too little memory to tomcat.
Not sure if it's the same way to configure this on Windows, but here goes:
Add the following line in the file <CATALINA_HOME>/bin/catalina.sh
JAVA_OPTS=-Xmx128m
Remember to restart tomcat for the changes to take effect
jigsaw
Error
Postby drmaq » Mon Feb 11, 2008 11:03 pm
thanks but i got fed up and reinstalled it from scratch
drmaq
Postby mars96 » Fri Feb 15, 2008 6:04 pm
jigsaw wrote:Maybe you are allocating too little memory to tomcat.
JAVA_OPTS=-Xmx128m
He uses Jetty which is not Tomcat. Anyway it's more or less the same you have to do.
I assume you are using a start script for jetty if not create one.
Here is an example (you don't have to add the path to the java executable - I need it because I've different versions installed and currently backport Subsonic to Java 1.4):
------- startJettyjdk14 -----------------------
D:\Programme\Development\JavaRuntimes\j2sdk1.4.2_15\bin\java -Xmx128M -jar start.jar
You have to place the start script in the main Jetty directory where you'll also find the start.jar.
cu
mars96
