Can't Connect could not connect to it. (ConnectTimeoutExcep
Postby enaba » Fri Nov 09, 2012 2:58 pm
I am wondering if you can help me, my subsonic link stop working for no reason
Status: enaba.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
[2012-11-09 05:21:39,121] INFO DaoHelper - Checking database schema.
[2012-11-09 05:22:26,989] INFO DaoHelper - Done checking database schema.
[2012-11-09 05:22:36,694] INFO VersionService - Resolved local Subsonic version to: 4.7
[2012-11-09 05:22:43,363] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Sat Nov 10 03:00:00 GST 2012
[2012-11-09 05:22:44,675] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Fri Nov 09 05:27:44 GST 2012
[2012-11-09 05:22:48,578] INFO NetworkService - Successfully forwarding port 4040.
[2012-11-09 05:23:35,200] INFO VersionService - Resolved latest Subsonic final version to: 4.7
[2012-11-09 05:23:35,200] INFO VersionService - Resolved latest Subsonic beta version to: 4.7.beta3
[2012-11-09 05:24:10,567] INFO NetworkService - Successfully forwarding port 4040.
[2012-11-09 05:24:33,800] INFO NetworkService - Successfully forwarding port 4040.
[2012-11-09 05:27:53,147] INFO PodcastService - Starting scheduled Podcast refresh.
[2012-11-09 05:27:53,147] INFO PodcastService - Completed scheduled Podcast refresh.
[2012-11-09 06:24:37,364] INFO NetworkService - Successfully forwarding port 4040.
[2012-11-09 07:24:40,604] INFO NetworkService - Successfully forwarding port 4040.
[2012-11-09 08:24:43,819] INFO NetworkService - Successfully forwarding port 4040.
[2012-11-09 09:24:47,012] INFO NetworkService - Successfully forwarding port 4040.
Can anyone Help me ?
enaba
Re: Can't Connect could not connect to it. (ConnectTimeoutE
Postby bushman4 » Fri Nov 09, 2012 3:06 pm
Check the port forwarding on your firewall. Does it work from inside the network if you access it via the IP address and port number?
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby enaba » Fri Nov 09, 2012 3:23 pm
It works within the home network but outside it does not work.
I don't have a firewall enabled.
enaba
Postby hakko » Fri Nov 09, 2012 3:33 pm
Your machine doesn't answer at http://94.201.136.108:4040. Would you expect it to?
MusicCabinet developer
hakko
Postby bushman4 » Fri Nov 09, 2012 4:13 pm
enaba wrote:I don't have a firewall enabled.
Unless you are one of those strange people without ANYTHING between them and the internet, I highly doubt this...
Your home's internet router is also a firewall. You need to verify that the router is passing port 4040 traffic to the subsonic server's internal IP address.
HTH,
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby GJ51 » Fri Nov 09, 2012 8:43 pm
viewtopic.php?f=6&t=4867
Read the forst 2 posts VERY carefully.
Postby enaba » Sat Nov 10, 2012 2:09 pm
Thanks a lot, Will do now
enaba
Users browsing this forum: Google [Bot] and 22 guests
