Server-Error since a file-download near the end.
Postby D-Man » Wed Feb 13, 2008 8:37 pm
hi there,
i installed subsonic on my home-server in march 2007 and it worked fine for almost a year. but the last time a few other users including me get an error since downloading a mp3-file mostly when its over 90% independent from the web-browser.
subsonic doesnt write a line in the logfile.
i reinstalled the last stable version today with the windowsinstaller but nothing changed.
does anybody had had similar problems or can help me?
tia
regards
d-man
D-Man
Postby jigsaw » Wed Feb 13, 2008 9:37 pm
You might try setting the logging to debug-level and check the logs after you experience the error.
Edit the file <tomcat_home>/webapps/subsonic/WEB-INF/classes/log4j.properties
Change the log-level
log4j.rootLogger=DEBUG, A1
Restart tomcat
jigsaw
Postby D-Man » Wed Feb 13, 2008 10:14 pm
hmm, this path and file doesnt exist. im going to update java and will re-install tomcat and subsonic manually by hand.
D-Man
Postby D-Man » Thu Feb 14, 2008 7:01 am
good morning everybody,
i deinstalled the windows-installer-version of subsonic and installed everything new in its latest version instead of subsonic. subsonic is version 3.2 and it works fine.
i have to make more tests to see if the problem is solved or not.
regards
D-Man
Postby D-Man » Thu Feb 14, 2008 12:05 pm
after updating to version 3.3 i experienced the failures again but i noticed that everything works fine with ie and firefox without a downloadmanager. i think that "down them all" causes the problem and will have a look at it.
regards
D-Man
