Subsonic not updating library
Postby iCANNcu » Tue Nov 13, 2012 10:27 am
I'm having an issue with Subsonic 4.7 on windows vista. My media library isn't being updated, new song won't show up in subsonic. I've tried deleting and re-adding the media folders and i've tried uninstalling and reinstalling subsonic but both didn't help. Also the clean library command doesn't seem to do anything. How can i reinstall subsonic with a fresh library?
iCANNcu
Re: Subsonic not updating library
Postby iCANNcu » Wed Nov 14, 2012 10:44 am
Why am i not getting any replies? Did i not ask for help in the proper way? Or is it that no one has a clue?
I went to the #subsonic chanel on irc freenode and they mentioned that i need to find the location of the database and delete it. Where does subsonic store its database on windows vista? I'm having troubles finding it.
iCANNcu
Postby BKKKPewsey » Wed Nov 14, 2012 12:06 pm
Delete c:\subsonic folder - then re-install.
That will give you a clean install.
Postby iCANNcu » Wed Nov 14, 2012 3:14 pm
Thx that did the trick!
iCANNcu
Users browsing this forum: Google [Bot] and 13 guests
