Playlist not showing
Postby Anthonyza » Thu Nov 15, 2012 5:43 pm
The android app is working fine, server working fine, only thing is that all of a sudden it is not updating the playlists, I create a new playlist and the phone app won't see it, it only shows old playlists. Help.
Anthonyza
Re: Playlist not showing
Postby Anthonyza » Thu Nov 15, 2012 6:42 pm
i must add, the app says "no saved playlist on server" yet there is, playlists have worked fine until now.
Anthonyza
Postby Anthonyza » Fri Nov 16, 2012 7:20 am
Solved, I realised that now you have to actually share the playlist for it to be visible.
Anthonyza
Postby bushman4 » Fri Nov 16, 2012 2:02 pm
Unless you saved it under the same username that you are using on your phone...
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
