EQ and VIS items missing in Android app
Postby JamMstrT » Fri Nov 16, 2012 5:45 pm
I hope you can point me in the proper direction with this. I had upgraded the app on my Android phone and tablet when Google Play showed the update available. Everything worked fine immediately after the update on the phone. Everything seems to still be appearing normally on the tablet. However, within the last week or so the EQ and VIS items disappeared from the display on my phone. I have tried uninstalling and re-installing the app with no success. Any ideas how I can get these features back onto my phone?
Thanks in advance,
T
Regards,
T
If at first you don't succeed, destroy all evidence that shows you tried.
JamMstrT
Re: EQ and VIS items missing in Android app
Postby daneren2005 » Fri Nov 16, 2012 10:07 pm
I'd be interested to see if anyone else is having this issue as well. On my phone (HTC One X) it seems to have disappeared when I started using Beats EQ again. Maybe you are similarly using a system wide EQ which is causing it not to show up?
Postby Ameribucano » Mon Nov 19, 2012 6:06 pm
[edit] NEVERMIND, I found it...
at least it motivated me to register on the forums!
Ameribucano
Postby tnt533 » Mon Nov 19, 2012 7:49 pm
I've been experiencing this issue on and off for months. Right now the only option there is RC. There is no rhyme or reason to it.
tnt533
Postby patshi » Fri Nov 01, 2013 8:42 am
I'm on a HTC One and missing the EQ settings too. On my Sony Tablet S the RC and VIS settings are right there. The Sony has stock Android 4.0.3.
My System is:
HTC One 32GB
ROM: Android Revolution HD 22.0
Android 4.3
I tried restarting the phone while Beats is disabled, no luck so far.
Is it hidden anywhere else or is it a bug?
Patrick.
patshi
Postby danobegood » Tue Nov 05, 2013 12:47 pm
Course of events...
phone missing 4g two days prior. Go to vzw and tech removed/reinserted sim card. 4g returns. Two days later eq missing from android app. Clear cache, nada. Remove some unneeded apps, nada. Reboot, bingo. Droid4.
danobegood
