Admin Imported Playlists Won't Delete
Postby Commodore » Tue Nov 20, 2012 2:08 pm
Problem Description: Deleted playlists don't stay deleted. I have two playlists which I imported. I can delete them, but some amount of time after that they reappear completely intact for no apparent reason.
Troubleshooting Steps: I have attempted clearing the database, and restarting subsonic, to no avail. Playlists created (not imported) by other users seem to work fine. I haven't tested importing a playlist from other users.
Playback Application and version: N/A
Subsonic Version: Version 4.7 (build 3105) – September 11, 2012
Server Version: Server jetty-6.1.x, java 1.6.0_31, Linux (137.3 MB / 227.6 MB)
Hardware Platform: Linux Sabra 2.6.32-28-server #55-Ubuntu SMP Mon Jan 10 23:57:16 UTC 2011 x86_64 GNU/Linux
Java Memory Limit: SUBSONIC_ARGS="--max-memory=256"
Problem Filename: N/A
Output from ffmpeg -i: N/A
Last ten log file lines: This consists entirely of PlayQueueInputStream and AudioScrobblerService items. Nothing useful.
Let me know if you need any further information to help.
Commodore
Re: Admin Imported Playlists Won't Delete
Postby daneren2005 » Tue Nov 20, 2012 2:32 pm
Ran into the same issue. You need to delete the playlist file where it is being imported. Otherwise it will continually recreate it next time the server does it's daily scan.
Postby nyktovus » Tue Nov 19, 2013 8:52 pm
so where are these playlists stored?? where do i find them to delete them permanently..
nyktovus
