Can't connect to http://YOURNAME.subsonic.org
Postby truedink » Wed Nov 21, 2012 12:14 am
After donating I could connect to http://YOURNAME.subsonic.org for a couple of days.
Now when I try I'm getting the message "Status: truedink.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)"
What does this mean and have I wasted my money donating? How do I fix the problem?
Thanks.
truedink
Re: Can't connect to http://YOURNAME.subsonic.org
Postby GJ51 » Wed Nov 21, 2012 1:29 am
This webpage is not available
Google Chrome could not load the webpage because 2.123.42.141 took too long to respond. The website may be down, or you may be experiencing issues with your Internet connection.
Your router or firewall is not set up properly.
Go to Canyouseemee.org and enter 8080 to test to see if the port is open. If not, review your port forwarding on your router and make sure the site is accessible from inside your network to test for firewall blocking on the server.
