4.7 (build 3106) - Error in REST API: EofException
Postby ArsenicTrioxide » Wed Nov 21, 2012 4:20 pm
Version 4.7 (build 3106) – September 12, 2012
Server jetty-6.1.x, java 1.6.0_27, Windows 7
iPhone - iSub (Latest Version)
This is from a clean install.
My music is streaming fine from home. however, outside of the local network I cannot get the music to stream all the way through. it will stop about a quarter to half way through. If I try and stream by connecting through a web browser most times it won't even try to play the song. Here is a sample of the Log File
[2012-11-20 11:26:38,191] WARN RESTFilter - Error in REST API: EofException
org.mortbay.jetty.EofException
at org.mortbay.jetty.HttpGenerator.flush(HttpGenerator.java:760)
at org.mortbay.jetty.AbstractGenerator$Output.blockForOutput(AbstractGenerator.java:546)
at org.mortbay.jetty.AbstractGenerator$Output.flush(AbstractGenerator.java:567)
at org.mortbay.jetty.HttpConnection$Output.flush(HttpConnection.java:907)
at org.mortbay.jetty.AbstractGenerator$Output.write(AbstractGenerator.java:628)
at org.mortbay.jetty.AbstractGenerator$Output.write(AbstractGenerator.java:575)
at net.sourceforge.subsonic.io.RangeOutputStream.write(RangeOutputStream.java:143)
at net.sourceforge.subsonic.controller.StreamController.handleRequest(StreamController.java:221)
at net.sourceforge.subsonic.controller.RESTController.stream(RESTController.java:1080)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
at net.sourceforge.subsonic.security.RESTRequestParameterProcessingFilter.doFilter(RESTRequestParameterProcessingFilter.java:110)
at net.sourceforge.subsonic.filter.RESTFilter.doFilter(RESTFilter.java:51)
Caused by: java.io.IOException: An established connection was aborted by the software in your host machine
at sun.nio.ch.SocketDispatcher.write0(Native Method)
at sun.nio.ch.SocketDispatcher.write(Unknown Source)
at sun.nio.ch.IOUtil.writeFromNativeBuffer(Unknown Source)
at sun.nio.ch.IOUtil.write(Unknown Source)
at sun.nio.ch.SocketChannelImpl.write(Unknown Source)
at org.mortbay.io.nio.ChannelEndPoint.flush(ChannelEndPoint.java:166)
at org.mortbay.io.nio.SelectChannelEndPoint.flush(SelectChannelEndPoint.java:208)
at org.mortbay.jetty.HttpGenerator.flush(HttpGenerator.java:693)
... 69 more
ArsenicTrioxide
