Plays some tracks, not others
Postby Dogface051 » Fri Nov 23, 2012 11:18 pm
Applies to both Sonic and the paid subscription ROKU version. Sonic will play ALL that tracks that I own, but not the ones from Rhapsody that are stored in my computer. I can play the stored Rhapsody files on Windows Media Player and Real Player, but not on Sonic. Using ROKU, Sonic finds all the files and "plays" them (the timer counts down the remaining time left to play) but there is no sound. In the PC version, when I click the track to play, it makes a "click" and moves on to the next file in the queue, makes a sound, and moves on to the next track. The Rhapsody files have been downloaded to my PC for off-line use.
Running Windows XP Pro , SP3
4.7 (build 3106) – September 12, 2012
jetty-6.1.x, java 1.6.0_35, Windows XP (32.4 MB / 68.1 MB)
Log File
[11/23/12 3:53:36 PM MST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Error while decoding stream #0.0
[11/23/12 3:53:36 PM MST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Last message repeated 1 times
[11/23/12 3:53:36 PM MST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) [wmav2 @ 01EBC8C0] prev_block_len_bits 6 out of range
[11/23/12 3:53:36 PM MST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) [wmav2 @ 01EBC8C0] prev_block_len_bits 4 out of range
[11/23/12 3:53:36 PM MST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) [wmav2 @ 01EBC8C0] block_len_bits 5 out of range
[11/23/12 3:53:36 PM MST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) [wmav2 @ 01EBC8C0] prev_block_len_bits 5 out of range
[11/23/12 3:53:36 PM MST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) [wmav2 @ 01EBC8C0] next_block_len_bits 4 out of range
[11/23/12 3:53:36 PM MST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) [wmav2 @ 01EBC8C0] next_block_len_bits 6 out of range
[11/23/12 3:53:36 PM MST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) [wmav2 @ 01EBC8C0] block_len_bits 6 out of range
[11/23/12 3:53:36 PM MST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) [wmav2 @ 01EBC8C0] frame_len overflow
[11/23/12 3:53:36 PM MST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) [wmav2 @ 01EBC8C0] block_len_bits 4 out of range
[11/23/12 3:53:36 PM MST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) size= 4kB time=00:00:00.18 bitrate= 156.9kbits/s
[11/23/12 3:53:36 PM MST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) video:0kB audio:3kB global headers:0kB muxing overhead 22.632479%
[11/23/12 3:55:51 PM MST] INFO PodcastService Starting scheduled Podcast refresh.
[11/23/12 3:55:51 PM MST] INFO PodcastService Completed scheduled Podcast refresh.
Dogface051
Re: Plays some tracks, not others
Postby alphawave7 » Sat Nov 24, 2012 1:59 am
It is likely you have downloaded DRM WMA tracks from Rhapsody? Only a qualified player, like the two you mentioned, will play those tracks.
Postby grant420 » Mon Nov 26, 2012 8:51 pm
Or use certain sound editing software (e.g. Switch Sound File Converter - http://www.nch.com.au/switch/index.html) to open the DRM'd files, save as .wav (to strip the DRM), then re-encode to your favorite file type.
I stumbled upon this trick while creating a CD for my wedding that included a couple 320kbps (DRMd) .mp3s from Amazon.com that I wanted to convert to .wav and burn to a CD.
grant420
Postby hakko » Mon Nov 26, 2012 9:29 pm
Note that this last trick will decrease sound quality. If possible, try acquiring the same media non-DRM:ed instead.
MusicCabinet developer
hakko
Postby grant420 » Mon Nov 26, 2012 9:49 pm
hakko wrote:Note that this last trick will decrease sound quality. If possible, try acquiring the same media non-DRM:ed instead.
No, it won't decrease sound quality if you do it right. Save it as a .flac, then back as a .wav, for instance to never go down the compressed music file path.
grant420
Postby hakko » Mon Nov 26, 2012 10:11 pm
grant420 wrote:then re-encode to your favorite file type.
Most people don't have .wav as their favorite file type (and if you do, you'd probably want the original lossless file, not a lossy file re-encoded to .wav).
I'm aware that some music is hard to find and you might find yourself in a situation where this is your only option. But at the same time, I see people converting lossy-lossy way too often without realizing what's happening behind the scenes and not checking the spectrals of their music. So I'd just like to add that this technique should be used as a last resort and the resulting files shouldn't be spread.
hakko
Users browsing this forum: No registered users and 52 guests
