my registered address points to the wrong place
Postby nateshoe91 » Wed Nov 28, 2012 10:18 pm
i'm finally buying subsonic after having used it for a month during the summer. I'm reseting it up on the same computer. The service is set to run on port 8080,ports are forwarded, it loads when pointing to localhost:808, but my subdomain (musicjunkies.subsonic.org) points to 4040?
So, ok, i'll change the service to port 404. forward the ports, localhost:404 loads, but now musicjunkies.subsonic.org points to 8080!
whhichever i put is the opposite of what musicjunkies forwards to. Kinda confused.
nateshoe91
Re: my registered address points to the wrong place
Postby BKKKPewsey » Fri Nov 30, 2012 3:09 am
I can see your server np (or at least somebody's server) on port 8080
Postby nateshoe91 » Fri Nov 30, 2012 8:15 pm
Hey, it works now. Guess it just needed time to organize itself. I was in a hurry yesterday, so I guess that explains it
nateshoe91
Postby gurutech » Thu Dec 06, 2012 7:58 pm
Having similar issues on my end....
My registered site is pointing to the correct port #, but the wrong IP address. My ISP replaced my cable modem a week or so ago, and my IP address changed as a result. I never noticed it until today, as I normally don't use the "sitename.subsonic.org" address, since I have my own "sitename.domain.com" address that does the same thing as the subsonic.org address.
I noticed the problem when I tried using iSub on my iPhone... the address was still pointing to my old IP address, and I couldn't change the configured server setting to my own domain.com address in iSub, so I tested the subsonic.com address on my PC, and that's when I actually noticed the IP it was forwarding to was still my old one.
Checked settings in Subsonic, and the subsonic.org domain forwarding was actually disabled. Re-enabled it with my site name, and was forced to re-enter my license key (no problem there), but it still won't connect. I'm assuming it will just take a while to register my new IP address in the DNS records, so I'll wait a couple hours, but after that, I think I will either have to change my site name, or maybe contact Sindre directly to ask if the update can be done manually... :-)
Edit: Update - seems to be working now, although for some reason, the subsonic.org address forwards to the local IP address of my Subsonic server (192.168.x.x) on port 4040, and not my public IP address. But my iphone using iSub must forward to the public IP address, because I can still access server playlists and non-cached music when I have wifi disabled, and am going over 3G. (I think this may have been the reason I created my own domain in the first place!)
gurutech
Postby Chad » Mon Dec 10, 2012 3:36 am
IF you are inside your LAN it will assign to your local server IP address, outside it uses your ISP address. Pretty handy for keeping the usage off of your ISP for home listening.
Chad
