setting up subsonic as a web sub directory and forcing ssl
Postby barrydocks » Mon Dec 03, 2012 8:43 pm
My subsonic server is based on zentyal (ubuntu 12.04) and also acts as a gateway, mail server, etc.
I would like to set up subsonic to be accessed via a subdirectory of the web domain and force ssl at the same time, ie use https://mydomain/subsonic
I have already setup zarafa with forced ssl using this guide: http://www.zarafa.com/wiki/index.php/Securing_Zarafa_WebAccess_with_SSL but subsonic is on its own port ie http://mydonmain:4040
There is also this post http://forum.subsonic.org/forum/viewtopic.php?f=6&t=8525 but it deals with setting up a sub domain rather than a web directory
I have enabled subsonic ssl on port 4141 by altering /etc/default/subsonic to include:
SUBSONIC_ARGS="--max-memory=2064 --https-port=4141 --context-path=/subsonic"
I wonder of someone would be kind enough to tie these together?
barrydocks
Re: setting up subsonic as a web sub directory and forcing s
Postby barrydocks » Thu Dec 06, 2012 1:47 pm
barrydocks
Postby artens » Thu Dec 06, 2012 7:48 pm
Would you share your config file for apache?
You can leave out the specific IP or external domain, but I'm looking for the same issue and cannot get the solution working on my end (even without SSL).
artens
Postby artens » Thu Dec 06, 2012 8:08 pm
Fixed! 8)
For solution read here:
viewtopic.php?f=2&t=10890&p=49825#p49825
artens
