Delete main database
Postby digitalworlds » Fri Feb 29, 2008 1:13 am
Hey,
Anyway to delete the main database? I enabled all transcoding options, made sure the transcoding files were in the proper folder and still no luck. I tried just deleting the music folder from Subsonic but it kept the whole database.
After enabling the transcoders none of the .m4a's show up, they didn't even before it was enabled.
digitalworlds
Postby sindre_mehus » Fri Feb 29, 2008 6:32 am
Have you added .m4a to Settings > General > Music mask ?
And have you enabled the transcoders in Settings > Players > Active transcodings ?
Regards,
Postby digitalworlds » Sun Mar 02, 2008 3:19 am
The music mark did it, i didn't see that part. and yes the transcoders are all enabled and loaded.
digitalworlds
