[LINUX] subsonic stoped working, cant seem to get it running
Postby RemkoM » Wed Dec 05, 2012 3:57 pm
First of all, i'm a linux novice, not a noob :)
Im running the subsonic server on Ubuntu 12.04 now for a year, after having it ran on a windows machine for a few years now.
But this week i could not connect to it any more, when i try to start the service i get a permission denied, even when i try a sudo start. i remember installing Coutchpotato, but looking at the install tutorial (yes, i still need those for most applications :oops: )it doesn't come near subsonic.
now i been trying to fix things with a blunt axe. first i changed all folder permissions, then i try d to re-install, and un-install, then i deleted all folder as they are shown in the Deb package. and i installed the Madsonic Mod.. but nothing!
i know service is started: Started Subsonic [PID 5856, /var/subsonic/subsonic_sh.log] with sudo.
the web browser is telling me:
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://
and the subsonic.sh log is:
72 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@e1e2b3: display name [org.springframework.context.support.ClassPathXmlApplicationContext@e1e2b3]; startup date [Wed Dec 05 16:31:26 CET 2012]; root of context hierarchy
278 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
1599 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@e1e2b3]: org.springframework.beans.factory.support.DefaultListableBeanFactory@95041
1646 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@95041: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
1727 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: /usr/share/subsonic/subsonic.war
Extracting webapp to /var/subsonic/jetty/3288
1861 [main] INFO org.mortbay.log - jetty-6.1.x
1976 [main] INFO org.mortbay.log - Extract jar:file:/usr/share/subsonic/subsonic.war!/ to /var/subsonic/jetty/3288/webapp
[GC 16192K->4148K(61824K), 0.0178430 secs]
[GC 20340K->2596K(61824K), 0.0099400 secs]
[GC 18788K->2600K(61824K), 0.0083100 secs]
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/usr/share/subsonic/subsonic-booter-jar-with-dependencies.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/var/subsonic/jetty/3288/webapp/WEB-INF/lib/slf4j-log4j12-1.6.1.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
[GC 18792K->3664K(61824K), 0.0112270 secs]
7066 [main] INFO / - Initializing Spring root WebApplicationContext
7067 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
7152 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@157133c: display name [Root WebApplicationContext]; startup date [Wed Dec 05 16:31:33 CET 2012]; root of context hierarchy
7295 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
7602 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
7795 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-cache.xml]
[GC 19856K->4772K(61440K), 0.0136520 secs]
7916 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@157133c]: org.springframework.beans.factory.support.DefaultListableBeanFactory@e4ec18
8193 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@e4ec18: defining beans [playerDao,mediaFileDao,artistDao,albumDao,playlistDao,internetRadioDao,musicFileInfoDao,hotDao,groupDao,accessRightDao,musicFolderDao,userDao,transcodingDao,podcastDao,avatarDao,shareDao,daoHelper,mediaFileService,securityService,settingsService,mediaScannerService,searchService,networkService,playerService,playlistService,versionService,statusService,musicInfoService,hotService,musicIndexService,audioScrobblerService,transcodingService,shareService,podcastService,jukeboxService,metaDataParserFactory,ajaxMultiService,ajaxNowPlayingService,ajaxPlayQueueService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxStarService,ajaxTagService,ajaxTransferService,ajaxChatService,MediaFileComparator,filterChainProxy,httpSessionContextIntegrationFilter,logoutFilter,authenticationProcessingFilter,basicProcessingFilter,restRequestParameterProcessingFilter,basicProcessingFilterEntryPoint,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,exceptionTranslationFilter,basicExceptionTranslationFilter,filterInvocationInterceptor,accessDecisionManager,rememberMeServices,authenticationManager,daoAuthenticationProvider,userCacheWrapper,ldapAuthenticationProvider,bindAuthenticator,userDetailsServiceBasedAuthoritiesPopulator,ajaxServiceInterceptor,ajaxTagServiceSecure,ajaxTransferServiceSecure,cacheFactory,userCache,mediaFileMemoryCache,musicFileMemoryCache]; root of factory hierarchy
8337 [main] INFO org.springframework.jdbc.datasource.DriverManagerDataSource - Loaded JDBC driver: org.hsqldb.jdbcDriver
9086 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [org/springframework/jdbc/support/sql-error-codes.xml]
9278 [main] INFO org.springframework.jdbc.support.SQLErrorCodesFactory - SQLErrorCodes loaded: [DB2, Derby, H2, HSQL, Informix, MS-SQL, MySQL, Oracle, PostgreSQL, Sybase]
[GC 20416K->8237K(61568K), 0.0210850 secs]
[GC 22317K->9613K(63296K), 0.0219290 secs]
[GC 23693K->11479K(76992K), 0.0319780 secs]
13307 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
13350 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public net.sourceforge.subsonic.ajax.UploadInfo net.sourceforge.subsonic.ajax.TransferService.getUploadInfo()] with attributes [[ROLE_UPLOAD]]
13350 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public java.lang.String net.sourceforge.subsonic.ajax.TagService.setTags(int,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String)] with attributes [[ROLE_COVERART]]
13351 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
13440 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization completed in 6373 ms
13579 [main] INFO / - Initializing Spring FrameworkServlet 'subsonic'
13579 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization started
13582 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@1e5babf: display name [WebApplicationContext for namespace 'subsonic-servlet']; startup date [Wed Dec 05 16:31:40 CET 2012]; parent: org.springframework.web.context.support.XmlWebApplicationContext@157133c
13583 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/subsonic-servlet.xml]
13947 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@1e5babf]: org.springframework.beans.factory.support.DefaultListableBeanFactory@1df71e6
14224 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1df71e6: defining beans [artistController,leftController,rightController,chatController,arrowchatController,statusController,mainController,playlistController,importPlaylistController,topController,helpController,LogController,moreController,moreeController,uploadController,upwinController,statisticsController,lyricsController,allmusicController,podcastController,podcastReceiverController,podcastReceiverAdminController,setMediaFileController,setMusicFileInfoController,shareManagementController,setRatingController,setHotController,randomPlayQueueController,groupSettingsController,accessSettingsController,cleanupSettingsController,iconSettingsController,loadPlaylistController,changeCoverArtController,nowPlayingController,starredController,searchController,settingsController,playerSettingsController,shareSettingsController,musicFolderSettingsController,networkSettingsController,transcodingSettingsController,internetRadioSettingsController,podcastSettingsController,generalSettingsController,advancedSettingsController,personalSettingsController,avatarUploadController,userSettingsController,passwordSettingsController,homeController,editTagsController,radioController,genresController,playQueueController,coverArtController,avatarController,proxyController,statusChartController,userChartController,m3uController,streamController,hlsController,videoPlayerController,externalPlayerController,downloadController,donateController,MadsonicController,multiController,wapController,restController,dbController,donateValidator,userSettingsValidator,passwordSettingsValidator,urlMapping,messageSource,themeSource,localeResolver,themeResolver,viewResolver]; parent: org.springframework.beans.factory.support.DefaultListableBeanFactory@e4ec18
[GC 38679K->12682K(77952K), 0.0248960 secs]
[GC 39882K->11963K(86336K), 0.0238860 secs]
17681 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization completed in 4102 ms
17718 [main] WARN org.mortbay.log - failed SelectChannelConnector@0.0.0.0:4040
java.net.BindException: Address already in use
   at sun.nio.ch.Net.bind0(Native Method)
   at sun.nio.ch.Net.bind(Net.java:344)
   at sun.nio.ch.Net.bind(Net.java:336)
   at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:199)
   at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74)
   at org.mortbay.jetty.nio.SelectChannelConnector.open(SelectChannelConnector.java:211)
   at org.mortbay.jetty.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:309)
   at org.mortbay.jetty.Server.doStart(Server.java:228)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:131)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
   at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
   at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
   at java.lang.reflect.Constructor.newInstance(Constructor.java:525)
[GC 47675K->13205K(86400K), 0.0273120 secs]
17754 [main] WARN org.mortbay.log - failed Server@3bec9c
17898 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
18042 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl_Stub[UnicastRef [liveRef: [endpoint:[127.0.1.1:9412](remote),objID:[0:0:0, 0]]]]
[GC 15566K->13387K(86464K), 0.0152390 secs]
[Full GC 13387K->9476K(86464K), 0.3068040 secs]
Maybe someone can help me to flush my system and reset the things that might be involved besides the standard subsonic folders/files.
any help would be much appreciated as im pulling my hair, and i hate to reinstall ubuntu (although you know that that would be a great learning experience!)
RemkoM
Re: [LINUX] subsonic stoped working, cant seem to get it run
Postby RemkoM » Thu Dec 06, 2012 11:40 am
Progress: after fooling around a bit, i installed open java, AND i changed port numbers, funny thing is that it seems my old port is beeing held hostage by Java:
sudo netstat -tulpn | grep :10085
tcp6 0 0 :::10085 :::* LISTEN 3100/java
i guess changing port numbers helps,
Question now is, might someone know how i can correct this so my Friends can reconnect without having to change there settings?
i assume killing process 3100 and changing port numbers might work, or do i F up java that way?
Any comments would be appreciated!
RemkoM
Postby sir2u » Thu Dec 06, 2012 12:32 pm
The log entry shows that the port is already in use:
Did you stop the subsonic service before you reinstalled? Reinstalling isn't going to stop the service. The already running instance is going to stay up and consume the resources. I'd venture to say a reboot might be your safest bet right now just to flush out all the running instances. If that's not possible, then yes, it should be safe to kill all those other processes.
sir2u
Users browsing this forum: No registered users and 42 guests
