Unable to access server from mobile after creating playlists
Postby innerspaceboy » Wed Dec 05, 2012 11:44 pm
Long-time user with a 50,000 song library, finally decided to explore the concept of playlists.
Generated the following starter playlists from within the Subsonic desktop interface -
Brian Eno Archive (517)
Deutsche Grammophon Avant Garde Archive (79)
Early Synthesizer and Moog Archive (544)
Electroacoustic Archive Part 1 (284)
Electroacoustic Archive Part 2 (235)
John Cage Archive (700)
Karlheinz Stockhausen Archive (1201)
Klaus Schulze Archive (29)
La Monte Young / Eternal Music Archive (86)
Morton Subotnick Archive (12)
Philip Glass Archive (536)
Philips Prospective 21e siecle Archive (96)
Tangerine Dream Archive (1483)
Problem:
They each queue up and play properly from within the Web interface, but on my Android device when I tap the 'Playlists' button it times out after several tries and reports:
ERROR
A network error occurred. Please check the server address or try again later.
When I attempted to refresh my library on the Android device I discovered that I'd lost all connectivity to my subsonic network. I can log in and play tracks from the PC with no problem, but I receive the "Network error occurred" time-out message on my phone when I try to refresh my music library or when I select my server from the server menu.
Attempts at resolution
1) Checked the Web interface Log and no errors are reported
2) Stopped and re-started the Subsonic desktop process
3) Selected the Demo server on my Android device and tested playlists - they load with no issue
4) Re-selected my server, no access.
5) Stopped and restarted the Android app. No change.
6) Turned off the PC and the phone. Restarted. Verified Subsonic working on PC. Still dead on phone.
Version:
Windows 7, Subsonic v4.7.
The only other thing that has happened today on my PC was a Windows Update (which I've disabled for the future.)
Curious if my playlists are too long for the app to handle? (a few are 1200-1483 tracks) The playlists that only denote 12 and 29 files contain album-length FLACs, so their playlist lengths are approx. 6-18 hrs each. The longer lists are around 155 hours each.
Thanks for any input! Once I get this working I plan to explore Musiccabinet to better manage my library. I'd love to hear solutions if the problem is indeed playlist size, particularly so that I can generate a Ninjatune record label playlist (153 hr) and an Underworld Mk1-Mk3 playlist (193 hr).
Such lists would greatly facilitate access to their albums!
innerspaceboy
Re: Unable to access server from mobile after creating playl
Postby daneren2005 » Thu Dec 06, 2012 1:11 am
Try browsing to the web interface from your phone's browser. That would be the first test to make sure it's solely an app problem.
Postby innerspaceboy » Thu Dec 06, 2012 1:23 am
Spinning blue wheel of torment, followed by message "server at xxxxx is taking too long to respond.
Google connects fine, as does the Demo Subsonic server.
Going to uninstall and re-install the mobile app next.
innerspaceboy
Postby GJ51 » Thu Dec 06, 2012 1:48 am
You need to verify that the Subsonic server is actually reachable from outside your network. Test the Subsonic port at http://Canyouseeme.org to verify.
Postby daneren2005 » Thu Dec 06, 2012 2:00 am
innerspaceboy wrote:Spinning blue wheel of torment, followed by message "server at xxxxx is taking too long to respond.
If it's not able to connect from the browser either then it isn't a app problem. Reinstalling it won't do squat.
