dynamic dns is not working [Resolved]
Postby Devlik » Fri Dec 07, 2012 3:39 pm
The error message I am getting is myname.subsonic.org responded successfully, but could not authenticate it. However, if I access the page via external IP it works fine. The ip address I am getting when I ping myname.subsonic.org is 66.49.215.227 which appears to be the stock website ip. I have donated and registered the software I have also restarted the service multiple times. http://xx.xx.128.217:4040 Works fine which is my current IP. I don't know how long it will be for but that is what it was at the time of posting. and the link works fine. I would just like to get the dynamic dns working as it was a large part of why I donated.
Mod Edited out IP and SS address for user security
Devlik
Re: dynamic dns is not working
Postby BKKKPewsey » Fri Dec 07, 2012 4:23 pm
I can see your SS fine using the yourname.subsonic.org address
(Well I can see somebodies SS :roll: )
Postby bushman4 » Fri Dec 07, 2012 4:29 pm
Subsonic does not run a dynamic DNS service. It runs a Web Redirection service.
Every name.subsonic.org will resolve to the same address. But when a web request is sent to that address with the host header of a known subsonic alias it will reply with a "302- temporarily moved, try..." message including your dynamic IP/port combination.
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Re: dynamic dns is not working (fixed)
Postby Devlik » Fri Dec 07, 2012 4:38 pm
Thank you so much for the explanation. I completely misunderstood how this service worked!
Devlik
Users browsing this forum: No registered users and 44 guests
