Bad SQL grammar; can't log in, Windows 8
Postby djmsalem » Wed Dec 12, 2012 3:19 pm
Decided to try Windows 8 as a fresh installation and after installing SS, receive the following long error message when I try to log in:
Exception org.springframework.jdbc.BadSqlGrammarException
Message PreparedStatementCallback; bad SQL grammar [select username, locale, theme_id, final_version_notification, beta_version_notification, main_caption_cutoff, main_track_number, main_artist, main_album, main_genre, main_year, main_bit_rate, main_duration, main_format, main_file_size, playlist_caption_cutoff, playlist_track_number, playlist_artist, playlist_album, playlist_genre, playlist_year, playlist_bit_rate, playlist_duration, playlist_format, playlist_file_size, last_fm_enabled, last_fm_username, last_fm_password, transcode_scheme, show_now_playing, selected_music_folder_id, party_mode_enabled, now_playing_allowed, avatar_scheme, system_avatar_id, changed, show_chat from user_settings where username=?]; nested exception is java.sql.SQLException: Column not found: FINAL_VERSION_NOTIFICATION in statement [select username, locale, theme_id, final_version_notification, beta_version_notification, main_caption_cutoff, main_track_number, main_artist, main_album, main_genre, main_year, main_bit_rate, main_duration, main_format, main_file_size, playlist_caption_cutoff, playlist_track_number, playlist_artist, playlist_album, playlist_genre, playlist_year, playlist_bit_rate, playlist_duration, playlist_format, playlist_file_size, last_fm_enabled, last_fm_username, last_fm_password, transcode_scheme, show_now_playing, selected_music_folder_id, party_mode_enabled, now_playing_allowed, avatar_scheme, system_avatar_id, changed, show_chat from user_settings where username=?]
Java version Sun Microsystems Inc. 1.6.0_27
Operating system Windows NT (unknown) 6.2
Server jetty-6.1.x
Memory Used 17 of 41 MB
Stack trace org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [select username, locale, theme_id, final_version_notification, beta_version_notification, main_caption_cutoff, main_track_number, main_artist, main_album, main_genre, main_year, main_bit_rate, main_duration, main_format, main_file_size, playlist_caption_cutoff, playlist_track_number, playlist_artist, playlist_album, playlist_genre, playlist_year, playlist_bit_rate, playlist_duration, playlist_format, playlist_file_size, last_fm_enabled, last_fm_username, last_fm_password, transcode_scheme, show_now_playing, selected_music_folder_id, party_mode_enabled, now_playing_allowed, avatar_scheme, system_avatar_id, changed, show_chat from user_settings where username=?]; nested exception is java.sql.SQLException: Column not found: FINAL_VERSION_NOTIFICATION in statement [select username, locale, theme_id, final_version_notification, beta_version_notification, main_caption_cutoff, main_track_number, main_artist, main_album, main_genre, main_year, main_bit_rate, main_duration, main_format, main_file_size, playlist_caption_cutoff, playlist_track_number, playlist_artist, playlist_album, playlist_genre, playlist_year, playlist_bit_rate, playlist_duration, playlist_format, playlist_file_size, last_fm_enabled, last_fm_username, last_fm_password, transcode_scheme, show_now_playing, selected_music_folder_id, party_mode_enabled, now_playing_allowed, avatar_scheme, system_avatar_id, changed, show_chat from user_settings where username=?]
at org.springframework.jdbc.support.SQLErrorCodeSQLExceptionTranslator.doTranslate(SQLErrorCodeSQLExceptionTranslator.java:220)
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:120)
at net.sourceforge.subsonic.dao.UserDao.getUserSettings(UserDao.java:166)
at net.sourceforge.subsonic.service.SettingsService.getUserSettings(SettingsService.java:1123)
at net.sourceforge.subsonic.controller.MultiController.index(MultiController.java:184)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
Caused by: java.sql.SQLException: Column not found: FINAL_VERSION_NOTIFICATION in statement [select username, locale, theme_id, final_version_notification, beta_version_notification, main_caption_cutoff, main_track_number, main_artist, main_album, main_genre, main_year, main_bit_rate, main_duration, main_format, main_file_size, playlist_caption_cutoff, playlist_track_number, playlist_artist, playlist_album, playlist_genre, playlist_year, playlist_bit_rate, playlist_duration, playlist_format, playlist_file_size, last_fm_enabled, last_fm_username, last_fm_password, transcode_scheme, show_now_playing, selected_music_folder_id, party_mode_enabled, now_playing_allowed, avatar_scheme, system_avatar_id, changed, show_chat from user_settings where username=?]
at org.hsqldb.jdbc.jdbcPreparedStatement.(Unknown Source)
at org.hsqldb.jdbc.jdbcConnection.prepareStatement(Unknown Source)
at org.springframework.jdbc.core.JdbcTemplate$SimplePreparedStatementCreator.createPreparedStatement(JdbcTemplate.java:1322)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:585)
... 68 more
Any idea as to what ails me? Aside from installing Windows 8 in the first place...?
David
djmsalem
Users browsing this forum: Google [Bot] and 20 guests
