[SOLVED] zentyal 3.0, ldap & subsonic
Postby barrydocks » Fri Dec 14, 2012 7:23 pm
I am trying out subsonic on my latest install of Zentyal 3.0. My problem is trying to get subsonic to authenticate against zentyals ldap directory. I have been happily using this with zentyal 2.0 for several years.
I have followed this guide: http://trac.zentyal.org/wiki/Documentation/Community/HowTo/Subsonic and altered the port number to 390 which is correct for Zentyal 3.0.
Here's the subsonic log:
[2012-12-14 19:16:54,231] INFO SubsonicLdapBindAuthenticator - Failed to authenticate user 'natalie' in LDAP.
org.acegisecurity.ldap.LdapDataAccessException: LdapCallback;[LDAP: error code 32 - No Such Object]; nested exception is javax.naming.NameNotFoundException: [LDAP: error code 32 - No Such Object]; remaining name ''
   at org.acegisecurity.ldap.LdapTemplate$LdapExceptionTranslator.translate(LdapTemplate.java:295)
   at org.acegisecurity.ldap.LdapTemplate.execute(LdapTemplate.java:128)
   at org.acegisecurity.ldap.LdapTemplate.searchForSingleEntry(LdapTemplate.java:246)
   at org.acegisecurity.ldap.search.FilterBasedLdapUserSearch.searchForUser(FilterBasedLdapUserSearch.java:119)
   at org.acegisecurity.providers.ldap.authenticator.BindAuthenticator.authenticate(BindAuthenticator.java:71)
   at net.sourceforge.subsonic.ldap.SubsonicLdapBindAuthenticator.authenticate(SubsonicLdapBindAuthenticator.java:72)
   at org.acegisecurity.providers.ldap.LdapAuthenticationProvider.retrieveUser(LdapAuthenticationProvider.java:233)
   at org.acegisecurity.providers.dao.AbstractUserDetailsAuthenticationProvider.authenticate(AbstractUserDetailsAuthenticationProvider.java:119)
   at org.acegisecurity.providers.ProviderManager.doAuthentication(ProviderManager.java:195)
   at org.acegisecurity.AbstractAuthenticationManager.authenticate(AbstractAuthenticationManager.java:45)
   at org.acegisecurity.ui.webapp.AuthenticationProcessingFilter.attemptAuthentication(AuthenticationProcessingFilter.java:71)
   at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:252)
   at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:844)
   at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:644)
Caused by: javax.naming.NameNotFoundException: [LDAP: error code 32 - No Such Object]; remaining name ''
   at com.sun.jndi.ldap.LdapCtx.mapErrorCode(LdapCtx.java:3057)
   at com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:2978)
   at com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:2785)
   at com.sun.jndi.ldap.LdapCtx.searchAux(LdapCtx.java:1839)
   at com.sun.jndi.ldap.LdapCtx.c_search(LdapCtx.java:1762)
   at com.sun.jndi.ldap.LdapCtx.c_search(LdapCtx.java:1779)
   at com.sun.jndi.toolkit.ctx.ComponentDirContext.p_search(ComponentDirContext.java:412)
   at com.sun.jndi.toolkit.ctx.PartialCompositeDirContext.search(PartialCompositeDirContext.java:394)
   at com.sun.jndi.toolkit.ctx.PartialCompositeDirContext.search(PartialCompositeDirContext.java:376)
   at javax.naming.directory.InitialDirContext.search(InitialDirContext.java:284)
   at org.acegisecurity.ldap.LdapTemplate$3.doInDirContext(LdapTemplate.java:249)
   at org.acegisecurity.ldap.LdapTemplate.execute(LdapTemplate.java:126)
   ... 38 more
Any help would be warmly welcome :D
barrydocks
Re: zentyal 3.0, ldap & subsonic
Postby barrydocks » Sat Dec 15, 2012 12:05 pm
solved, see this post on the zentyal forum:
http://forum.zentyal.org/index.php/topic,13412.0.html
barrydocks
