Subsonic can't access NAS
Postby pserian » Thu Dec 20, 2012 11:01 pm
-Subsonic Help Request---------------------->
Problem Description: During setup of the media folders, I receive the message "No media folders found. Please change the settings."
Troubleshooting Steps: Went into services.msc and changed the "Log on as" to my windows username instead of "Local Machine" by adding my username, which has admin privileges. Mapped the NAS to a different drive letter. Tried entering the path in subsonic setting in both formats, "Z:\music" and "\\LS-CHL-V20CF\Media\Music". Verified port 4040 is open. Confirmed you don't need a username or password to access the NAS drive from my computer. NAS is a Buffalo Linkstation LS-CHL.
Playback Application and version: Motorola Defy XT running on Android platform.
Subsonic Version: 4.7 (build 3106) – September 12, 2012
Server Version: jetty-6.1.x, java 1.7.0_10, Windows 7 (32.6 MB / 45.7 MB)
Hardware Platform: Windows 7
Java Memory Limit: 150
Problem Filename: Subsonic can't access "Z:\music" or "\\LS-CHL-V20CF\Media\Music"
Output from ffmpeg -i: when i typed in 'ffmpeg -i <Z:\music>' it says "Access is denied"
Last ten log file lines: (The last ten or so lines copied and pasted from the About screen in the Subsonic Web Interface. Ideally these will be in a CODE block as well.) I can't find any code in the "About" screen.
Peter
pserian
Re: Subsonic can't access NAS
Postby pserian » Wed Dec 26, 2012 3:51 pm
Hi again, I'm not sure if the staff is on vacation or not, but I'm still struggling with this problem. Any suggestions are much appreciated.
Peter
pserian
