XML/XSD validation issue
Postby tsm11 » Fri Mar 07, 2008 3:39 am
Hi -- I'm on Windows Vista Ultimate, using tomcat 6 and java 6... seems odd to be getting this old message.
I had an older version of subsonic running without issue before (at least a couple versions old).
Caused by: javax.xml.parsers.ParserConfigurationException: Unable to validate using XSD: Your JAXP provider [org.apache.crimson.jaxp.DocumentBuilderFactoryImpl@128215d] does not support XML Schema. Are you running on Java 1.4 or below with Apache Crimson? Upgrade to Apache Xerces (or Java 1.5) for full XSD support.
Here is the full stack:
INFO: HTMLManager: start: Starting web application at '/subsonic'
Mar 6, 2008 7:54:40 PM org.apache.catalina.core.ApplicationContext log
INFO: Initializing Spring root WebApplicationContext
[2008-03-06 19:54:40,584] ERROR org.springframework.web.context.ContextLoader - Context initialization failed
org.springframework.beans.factory.BeanDefinitionStoreException: Parser configuration exception parsing XML from ServletContext resource [/WEB-INF/applicationContext-service.xml]; nested exception is javax.xml.parsers.ParserConfigurationException: Unable to validate using XSD: Your JAXP provider [org.apache.crimson.jaxp.DocumentBuilderFactoryImpl@128215d] does not support XML Schema. Are you running on Java 1.4 or below with Apache Crimson? Upgrade to Apache Xerces (or Java 1.5) for full XSD support.
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:377)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:313)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:290)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:142)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:158)
at org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:124)
at org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:92)
at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:97)
at org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:411)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:338)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:251)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:190)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3827)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4334)
at org.apache.catalina.manager.ManagerServlet.start(ManagerServlet.java:1237)
at org.apache.catalina.manager.HTMLManagerServlet.start(HTMLManagerServlet.java:588)
at org.apache.catalina.manager.HTMLManagerServlet.doGet(HTMLManagerServlet.java:128)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:230)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:525)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:104)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:563)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:261)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:581)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:619)
at org.springframework.beans.factory.xml.DefaultDocumentLoader.createDocumentBuilderFactory(DefaultDocumentLoader.java:105)
at org.springframework.beans.factory.xml.DefaultDocumentLoader.loadDocument(DefaultDocumentLoader.java:72)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:361)
... 33 more
Mar 6, 2008 7:54:40 PM org.apache.catalina.core.StandardContext listenerStart
SEVERE: Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
... 33 more
Mar 6, 2008 7:54:40 PM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
SEVERE: Context [/subsonic] startup failed due to previous errors
INFO: Closing Spring root WebApplicationContext
tsm11
How I fixed it.
Postby tsm11 » Wed Mar 19, 2008 6:56 pm
I found on another (Spring?) forum that this error occurs when there are competing xml api's.
To fix it, I upgraded to Tomcat 6.0.16 and all is fine. I probably could have fixed it without upgrading by finding the competing xml api jars, but FWIW tomcat 6.0.13 had some other issues, like losing the dbcp socket after 12 hours idle.
tsm11
Users browsing this forum: No registered users and 69 guests
