Subsonic Cover art problem :(
Postby djh82uk » Tue Mar 25, 2008 4:03 pm
Hiya all
Im trying to get subsonic working, it works but I just cannot update any cover art for the albums, I get 2 different error messages in the log.
[2008-03-25 02:36:53,174] WARN CoverArtController - Failed to create thumbnail for /home/djh/samba/music/Sonics, the [1966] Boom/folder.jpg
java.lang.NoClassDefFoundError
at com.sun.imageio.plugins.jpeg.JPEGImageReaderSpi.cr eateReaderInstance(JPEGImageReaderSpi.java:89)
at javax.imageio.spi.ImageReaderSpi.createReaderInsta nce(ImageReaderSpi.java:296)
at javax.imageio.ImageIO$ImageReaderIterator.next(Ima geIO.java:48
at javax.imageio.ImageIO$ImageReaderIterator.next(Ima geIO.java:472)
at javax.imageio.ImageIO.read(ImageIO.java:1397)
at javax.imageio.ImageIO.read(ImageIO.java:1322)
I also get this error:
[2008-03-25 02:36:52,983] WARN CoverArtController - Failed to create thumbnail for /home/djh/samba/music/Robyn - Robyn (2007)/folder.jpg
java.lang.UnsatisfiedLinkError: /usr/lib/jvm/java-1.5.0-sun-1.5.0.13/jre/lib/i386/libawt.so: Can't load IA 32-bit .so on a IA 32-bit platform
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.jav a:1751)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java :166
at java.lang.Runtime.loadLibrary0(Runtime.java:822)
Ive shortened them a bit as the log is huge, it's just the same old stuff again.
Cany anyone help?
It was working fine, then It stopped working so I had to remove subsonic and re-install (removed /var/subsonic and put a new subsonic.war in webapps)
DJH
djh82uk
Postby djh82uk » Thu Mar 27, 2008 2:18 pm
anyone?
DJH
djh82uk
Postby djh82uk » Fri Mar 28, 2008 2:57 am
Ok, I changed some permissions, and I now get:
Can't create cache file!
anyone help?
djh82uk
Postby sindre_mehus » Fri Mar 28, 2008 5:18 am
I'm not sure what you refer to, but if Subsonic is unable to create the thumbnail cache directory (typically /var/subsonic/thumbs), you'll see this log entry:
ERROR - Failed to create thumbnail cache /var/subsonic/thumbs
Cheers,
Postby djh82uk » Fri Mar 28, 2008 2:15 pm
hmm, yes it's looking like it has nothing to do with thumbs, it does update the cover art in the folder, names it correctly etc, it just isn't displayed. ANy ideas?
djh82uk
Postby djh82uk » Fri Mar 28, 2008 2:19 pm
Hmm Im now getting this
I have reset the permissions to user "tomat55"
Exception java.io.IOException
Message Failed to create thumbnail for /home/djh/external/music/Avril Lavigne - Let Go/folder.jpg. null
Still everything works ok, except for displaying cover art
djh82uk
Postby sindre_mehus » Fri Mar 28, 2008 2:57 pm
Could you please include the stack trace with more detailed info? (See TOMCAT_HOME/subsonic.log)
