Video Transcoding Tips? Streaming ANY Vid Maxes my CPU
Postby kettlnaut » Wed Jan 02, 2013 8:34 pm
I have an i3 sandy bridge 3.4 ghz multithreaded (dual core but shows 4 cores in windows) with 16GB of DDR3, a Nvidia 9800GT 1GB-DDR3, and a crapton of all sata drive space. I was running Win7 x64 Pro, recently upgraded to Win 8. no issues from the upgrade whatsoever, but this started before the Win 8 upgrade. Just curious if there are any tips I should know for optimizing settings for video streaming. Or if there is a plugin I should use.
Googling around I saw someone said convert all your videos to mp4, but I have a ton of videos and that would take next to forever, even on my current rig. Is this what subsonic folks suggest or is there a better way. Any tips would be greatly appreciated. thanks. :mrgreen:
kettlnaut
Re: Video Transcoding Tips? Streaming ANY Vid Maxes my CPU
Postby kettlnaut » Wed Jan 02, 2013 10:05 pm
OK so I lied, Mp4 files do indeed seem to play fine without maxing my CPU so I guess that is the answer. Sucks but knowing that is what it will take, guess I gotta just suck it up and find time to do it. Would be great if you guys could find a way to use VLC as transcode plugin. I not a dev so I have no clue how though so I guess I will just convert to mp4. This is still the bestest piece of software ever! :D
kettlnaut
Postby bushman4 » Fri Jan 04, 2013 4:26 pm
Before you do that, I would update ffmpeg.exe to the latest version. It is located in c:\subsonic\transcode. Newest versions are located here:
http://ffmpeg.zeranoe.com/builds/
You want the latest "static" build for your version of Windows (32 bit or 64 bit).
Then try to transcode from whatever format you have now on the fly...
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
