Java Errors
Java Errors
Postby pcarpen » Wed Mar 26, 2008 3:49 pm
My Subsonic install suddenly stopped working with this error:
Error
Exception org.springframework.jdbc.CannotGetJdbcConnectionException
Message Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: Unexpected token: �
Java version Sun Microsystems Inc. 1.6.0_03
Operating system Windows XP 5.1
Server jetty-6.1.x
Memory Used 5 of 7 MB
Stack trace org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: Unexpected token: � at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:82) at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:552) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:616) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:645)
I tried uninstalling both subsonic and Tomcat, but I get the same issues. I also tried using the Windows standalone installer, again with the same results. Could this be due to a new Java version.
pete
pcarpen
Postby sindre_mehus » Thu Mar 27, 2008 5:36 am
I haven't seen this before. Looks like the database is corrupt. It's located in c:\subsonic\db, and is a HSQL database.
If you are technically inclined you might wanna head to http://hsqldb.org/ and see if there are some database recovery tools. Otherwise, you can delete the entire c:\subsonic\db directory, and let it be re-created by Subsonic. You will of course loose all your data (users, statistics, config etc).
Cheers,
Postby pcarpen » Thu Mar 27, 2008 12:01 pm
Thanks Sindre. That did the trick. I simply deleted the C:\subsonic directory and let it genereate the database. I lost my settings, but those are easy to set up again. Thanks for your help.
pcarpen
