Deleted port mapping for port 4040
Postby jvpm » Sat Jan 05, 2013 2:20 am
I have the 4040 port open on my router.
Everytime I restart the subsonic service for whatever reason I get this on log:
[2013-01-05 02:13:24,909] INFO NetworkService - Deleted port mapping for port 4040
Why is it deleting the port mapping? From that point on I can't access the webUI.
jvpm
Re: Deleted port mapping for port 4040
Postby BKKKPewsey » Sat Jan 05, 2013 6:23 pm
jvpm wrote:Why is it deleting the port mapping?
I expect its because you have UPnP port fowarding disabled in settings/network
jvpm wrote:From that point on I can't access the webUI.
Then you haven't forwarded the port correctly in the router
Postby jvpm » Sun Jan 06, 2013 5:05 pm
The port is indeed forwarded correctly and I can access the webUI but whenever I restart the service it simply
deletes the port mapping (so I'm guessing the UPnP is activated).
Btw I'm using ubuntu server 12.10
Edit:
On subsonic page I tried the "Automatically configure your router to allow incoming connections to Subsonic (using UPnP or NAT-PMP port forwarding)." under
Settings > Network and I got this:
log:
Failed to create port forwarding.
net.sbbi.upnp.messages.UPNPResponseException: Detailed error code :501, Detailed error description :Action Failed
   at net.sbbi.upnp.messages.ActionMessageResponseParser.startElement(ActionMessageResponseParser.java:145)
   at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unknown Source)
   at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanStartElement(Unknown Source)
   at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
   at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
   at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
   at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
   at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
   at javax.xml.parsers.SAXParser.parse(SAXParser.java:392)
   at net.sbbi.upnp.messages.ActionMessage.service(ActionMessage.java:172)
   at net.sbbi.upnp.impls.InternetGatewayDevice.addPortMapping(InternetGatewayDevice.java:388)
   at net.sourceforge.subsonic.domain.SBBIRouter.addPortMapping(SBBIRouter.java:57)
   at net.sourceforge.subsonic.service.NetworkService$PortForwardingTask.execute(NetworkService.java:146)
   at net.sourceforge.subsonic.service.NetworkService$Task.run(NetworkService.java:309)
   at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
   at java.util.concurrent.FutureTask$Sync.innerRunAndReset(FutureTask.java:351)
   at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:178)
   at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:165)
   at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:267)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
   at java.lang.Thread.run(Thread.java:679)
jvpm
Postby BKKKPewsey » Sun Jan 06, 2013 10:06 pm
If you have auto port forwarding disabled you do get the deleted port mapping entry in the SS log on restart.
Why? - no idea :?
In your case it appears that the UPnP service is not understanding the response from your router so is throwing up that error.
If you can access SS ok then just ignore it
Generally it much better to manually forward the ports rather then relying on UPnP which I have found to rather unreliable :(
Postby jvpm » Sun Jan 06, 2013 10:39 pm
BKKKPewsey wrote:If you have auto port forwarding disabled you do get the deleted port mapping entry in the SS log on restart.
Why? - no idea :?
Aahah wicked!
Indeed, just tried restarting the service with the auto port forwarding enable and it's working. (bug!) :roll:
But hey, thanks I don't think I'd get this far without your help. :D
jvpm
Postby oggie » Tue Feb 19, 2013 5:26 pm
I'm seeing the same issue and I was wondering why this was happening... grrr.
If I disable the setting in SS, I get that message in the log.
If I enable it in SS, I get this:
[2013-02-19 13:33:23,293] INFO NetworkService - Successfully forwarding port 4040.
But neither works. But if I go into my router and add the port forwarding manually, it works. But once I restart SS, it fails again.
What's the proper setup and steps to make sure this always works and nothing is needed if SS is restarted?
oggie
Postby bushman4 » Tue Feb 19, 2013 6:51 pm
Ensure that your subsonic server computer always has the same internal IP address, either through a "reservation" on the DHCP server (the router, usually) or by hard coding an address into the server's network properties.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby oggie » Tue Feb 19, 2013 8:59 pm
That's not the problem. I have a static IPs.
The problem is subsonic is using upnp and talking to the router to delete the port forward rule. Everything work till I restart the subsonic service on my server.
oggie
Postby oggie » Wed Feb 20, 2013 12:19 am
I fixed the problem by:
1 - disabling upnp on my router
2 - adding port forward on my router to the static ip of the server
3 - disabling the automatically configure.... under settings/network in SS
oggie
