but some abuse the privilege!BKKKPewsey wrote:My server is running SS and using a vpn np.
Are you using yourname.subsonic.org address to access ?
If so start you vpn then access SS via local host or using your internal lan ip:port no
Then go to settings/network and hit the save button.
This will update the SS redirect to your new IP address.
GJ51 wrote:Your site doesn't respond from here so you have port forwarding or firewall issues.
If you can open your site inside your network, but I can't reach it from outside using ip:port format then either the router isn't sending the request to the host machine (or not to the right port) or the firewall is blocking the request.
