ERROR MESSAGE AFTER JAVA UPDATE
Postby jpotes99 » Mon Jan 14, 2013 4:48 pm
I did a JAVA update this morning and most of my music does not pLAy. SS says it is not found and when I try to do a scan it just stops. I also tried to do a data base clean up and get the following message:
Error
Message PreparedStatementCallback; SQL [select top 1 id from album where not present]; out of memory; nested exception is java.sql.SQLException: out of memory
Java version Oracle Corporation 1.7.0_11
Operating system Windows XP 5.1
Server jetty-6.1.x
Memory Used 45 of 145 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select top 1 id from album where not present]; out of memory; nested exception is java.sql.SQLException: out of memory
at org.springframework.jdbc.core.JdbcTemplate.queryForList(JdbcTemplate.java:768)
at net.sourceforge.subsonic.dao.AbstractDao.queryForInt(AbstractDao.java:97)
at net.sourceforge.subsonic.dao.AlbumDao.expunge(AlbumDao.java:203)
at net.sourceforge.subsonic.controller.MusicFolderSettingsController.expunge(MusicFolderSettingsController.java:72)
at net.sourceforge.subsonic.controller.MusicFolderSettingsController.formBackingObject(MusicFolderSettingsController.java:56)
at org.springframework.web.servlet.mvc.AbstractFormController.getErrorsForNewForm(AbstractFormController.java:358)
at org.springframework.web.servlet.mvc.AbstractFormController.showNewForm(AbstractFormController.java:338)
at org.springframework.web.servlet.mvc.AbstractFormController.handleRequestInternal(AbstractFormController.java:278)
Caused by: java.sql.SQLException: out of memory
... 65 more
jpotes99
