Only left ear working on some songs
Postby guite » Mon Jan 14, 2013 5:15 pm
Hi guys,
I have a problem with subsonic: when I use it as admin, everything goes fine, but when I run it with another user (whoever is admin or not), on certain songs (it does not depend on extension, it can be mp3), I can only hear the sound in my left ear. I tried to add a "-ac 2" parameter to ffmpeg command-line settings to force stereo, but this doesn't change anything. It might be a problem of rights on the file, and I don't really know which rights are needed for things to work correctly.
If more details are needed, I run subsonic on a synology DS212+ with java runtime 7. If any of you has any idea of what is the problem, hints are welcomed :-)
Many thanks,
guite
Re: Only left ear working on some songs
Postby guite » Tue Jan 15, 2013 8:35 am
Looks like this is due to the bitrate limit, I had a bitrate limit set to 192 kbps for this user and no limit for the admin. Songs for which bitrate is equal to 320 kbps have the problem I've mentioned (should be the same for bitrates > 192 kbps)... I still don't know why. Any idea ? :-)
Best regards,
guite
